Hi everyone.
I'm trying to revive my Cyrus DAD3 with a"new" CDM 12.4 (sold as new on ebay but it sure looks reclaimed to me).
During the dismantle I discovered a piece of the transport had fallen out on to my lap ( a small white plastic lever) - and I didn't see where it came from.
Does anyone have a service manual for this CD player?
thanks very much.
thanks very much.
Hey guys - I found the spot from this picture here:
http://img71.imageshack.us/img71/5884/88601730ry7.jpg
A pointer to the service manual would still be fantastic though.
Thanks very much.
Thanks very much.
Hi, I have exactly the same problem with my player, although it is a B&W Aura CD100 which uses the same mechanism. The white bit of plastic just fell out and I cant find how it goes back in. If you could post a picture of your solution (if you have found one!) I would really appreciate it
Thanks!
Thanks!
I assume, the loader is the 1265/10 from Philips, also used from Primare (CD31), Thule Audio (CD-150B), NAD (s500) and some CD-ROM drives for personal computers
But I am not sure as long I don't see the top view of the DAD3 mechanism.
If I am not right with my estimate, then the loader must be the 1210 (go to the last attachement - the Micromega stage). The mechanism and laser head in both loaders are the same: the CDM12.4.
Check out also this thread:
http://www.diyaudio.com/forums/digi...ayer-models-loader-l1265-l-1265-cdm-12-a.html
In the attachement you will find the exploded view of this loader - perhaps this will help.
Check also out the pics from post #24 about
http://www.diyaudio.com/forums/digital-source/180483-problem-quad-cd-77-help-needed-3.html
(Quad CD-77 bottom view)
and
http://www.vcdpickup.com/PHILIPS.htm
(various high resolution images)
and
I have the same problem - the white plastic lever fell out, and, even from the photos in this thread, I cannot figure out exactly where it goes, and how it stays there, without just tumbling around loosely in the innards. Any more details photos of exactly where & how it fits would be very welcome. Thanks!
Broken tray
Hello tiefbassuebertr
I don't know if you are still around???
I have a broken tray from the 1265/51 and I need a replacement... Do you have one by any chance? Or do you know if they are common to other loader units? Part 4822 418 10369 I think!
Dom
problem with quad cd 77 help needed
and
vcdpickup.com
Dom
Probably most of the units utilizing CDM12.4/05 will use the same tray (for example philips cdr-765 does on its the playback deck -both cd and cdr decks use same tray as I see on the SM-, Aura CD-100 too - not so many though and usually from quite pricey cd-players of that era). Also I think some CD-ROM/CD-R drives like CDD-3610 and maybe 2600 share the same tray (but in white).
- Digital Source
- Service Manual for Cyrus DAD3
