Service Manual for Cyrus DAD3
Hi everyone.
I'm trying to revive my Cyrus DAD3 with a"new" CDM 12.4 (sold as new on ebay but it sure looks reclaimed to me).
During the dismantle I discovered a piece of the transport had fallen out on to my lap ( a small white plastic lever) - and I didn't see where it came from.
Does anyone have a service manual for this CD player?
thanks very much.
Hi, I have exactly the same problem with my player, although it is a B&W Aura CD100 which uses the same mechanism. The white bit of plastic just fell out and I cant find how it goes back in. If you could post a picture of your solution (if you have found one!) I would really appreciate it
Thanks!
I assume, the loader is the 1265/10 from Philips, also used from Primare (CD31), Thule Audio (CD-150B), NAD (s500) and some CD-ROM drives for personal computers
But I am not sure as long I don't see the top view of the DAD3 mechanism.
If I am not right with my estimate, then the loader must be the 1210 (go to the last attachement - the Micromega stage). The mechanism and laser head in both loaders are the same: the CDM12.4.
Check out also this thread:
http://www.diyaudio.com/forums/digi...ayer-models-loader-l1265-l-1265-cdm-12-a.html
  • Loader L1265 exploded view I.pdf
  • Loader L1265 exploded view II.pdf
I have the same problem - the white plastic lever fell out, and, even from the photos in this thread, I cannot figure out exactly where it goes, and how it stays there, without just tumbling around loosely in the innards. Any more details photos of exactly where & how it fits would be very welcome. Thanks!
Broken tray
In the attachement you will find the exploded view of this loader - perhaps this will help.
Check also out the pics from post #24 about
problem with quad cd 77 help needed
(Quad CD-77 bottom view)
and
vcdpickup.com
(various high resolution images)
Hello tiefbassuebertr
I don't know if you are still around???
I have a broken tray from the 1265/51 and I need a replacement... Do you have one by any chance? Or do you know if they are common to other loader units? Part 4822 418 10369 I think!
Dom
Probably most of the units utilizing CDM12.4/05 will use the same tray (for example philips cdr-765 does on its the playback deck -both cd and cdr decks use same tray as I see on the SM-, Aura CD-100 too - not so many though and usually from quite pricey cd-players of that era). Also I think some CD-ROM/CD-R drives like CDD-3610 and maybe 2600 share the same tray (but in white).
