Look again, it is a regulator (feedback). T101/T102/R107 is a CCS for the resisor network R108 to R111, ...
Isn't your CCS based on the supply voltage / R105+R106?
Well, maybe not so much.
If the Vbe of T101 is operating in the flat slope then the effect of supply voltage on the CCS operating point will be very small.
OK, not as bad as I had originally thought.
I still would not do it that way though.
You figured it outWell, maybe not so much.
But you still prefer the zener reference?
LOL
Yes...on paper I prefer it.
But I have not tried it yet.
Time will tell.
Actually, if you would have used the output to source the CCS I would probably have accepted it.
How is the step response for 10% to 90% of load? (and 90% to 10% of load)
I use this as a stability indicator.
Time will tell.
