SemiSouth SJEP120R100 Single Ended Follower Amplifier, with Cascode and Choke Load
It's a hobby, I enjoy playing with Kicad (also LTSpice), so it's all fun for me. It's also great exercise for the brain.
And the cost was only CAN $4.65 (about US $3.60) for each channel (5 PCBs each) with slow shipping.
And it's not like I need another amplifier. I have more than enough amplifiers, so it's all about enjoying the DIY. It's fun, educational, and entertaining. 🙂
The left channel and up and running. It took quite a bit longer than anticipated because my work got sloppy, so I had to deal with a few bad solder joints and flux that I did not clean off. I spent quite a few hours figuring it out. I usually examine the solder joints closely and clean off the flux with alcohol but I didn't this time. However it is all good now and I am enjoying the amplifier.
The sound is quite similar to my Tokin follower amplifiers. I suppose that is to be expected as the distortion levels are similar. In my system, combined with the DIY2022 FE, it is a sound that I enjoy. This will be my new summer amplifier.
The distortion measured similar to the right channel. The left channel's maximum power output was slightly less than that of the right channel.
  • SJEP120R100 Cascoded Follower Amplifier setting Iq and cascode voltage.jpg
This is the first time that I experience an issue with flux. I had run out of trouble shooting ideas so I flooded the PCB with alcohol and it worked.
I am still a pcb newbie so many of the settings in Kicad have been left at default values but in the future, I will probably increase the clearance of 0.1mm in flood zones to 0.2mm or more. That will help prevent flux and solder issues.
