self answered (maybe) question about solder-technique
Joined 2017
Hi!
I don't recollect where I saw it, so unfortunately I can't link to it:
I once saw a picture of a finished board, where the resistors were wonderfully elevated something between 1 - 2 mm. Aside an advantage for temperature-issues, I guess this is mainly for aesthetics.
how is this done?
Soldered from the frontside with some support under every part? (I can't imagine any other way, but this seems to be quite a finicky burdensome job...)
Thanks for any tips!
best
david
Like in the attached image you mean?
These look soldered from the front side.
As I know in industry it is done with some flat spacer, for example some piece of heat-resistant plastic, etc. Or a holder (adaptor), like especial crocodile. (It is especial for every part).
As for me I did that with my hands (yes, I have very thick trained skin there 🙂 ). Now I don't - it was old fashion. Actual fashion is to put parts directly onto the PCB.
Precisely like this!
I just love that look...
I won't do it by hand (my poor princess' skin is way too precious :-D ) but I'll see if I can tinker something... or find another way...
THANKS!
I usually use a flat wooden stick, like the ones found in ice creams.
You can also use a thin piece of aluminium.
Anything that fits and you can remove it after soldering.
Good technique for bias resistors which generate a lot of heat, like in amplifier power stages.
> When I see the octal pins Juan shows
Yeahbut.... Octal pins don't neck-down like that. I lean to your Molex identification (if not something older). Of course in this crowd "Octal" gets the idea over quickly.
That is not 100% right. The elevation of power resistors is done to protect the PCB from overheating. While the resistor does not care much, the board may. When the resistor is elevated heat spread is also more even to ambient. Less hot spot phenomenon.
When I see the octal pins Juan shows, I always thought they were male Molex 09 pins. Peavey used a ton of them on amp boards.
Maybe they are !!!! 😛
I´ll have to defer to your experienced opinion 🙂
My pictures were found online after searching for "component standoff" and don´t claim ownership over them 😛
