Searching for a power supply design engineer
Who is the top quality people that can design a Linear Regulated Power Supply?
Must be very low noise (uv to nv)
Ability to run 5A on the +-48vdc lines with minimal effect on the the other voltages
CT Transformer is 117vac input and multi-tap secondary
I need the PS outputs to be:
+-48vdc
+-12vdc
+-19vdc
+6.3vac
Do you want the Top Quality designer to pay you? How much do you want them to pay you?
Do you want to pay the Top Quality Designer? How much do you want to pay them? Hourly rate, fixed price, or other arrangement?
Take a few minutes to exercise some Salesmanship. Explain to a Top Quality designer exactly WHY they should put aside their other projects, and work on your project instead? What is the additional benefit to them? How does their life improve if/when they decide to work on your job instead of Harmon Kardon International's job?
Top Quality designers have the luxury to pick and choose. Sell them on picking you. Sell them on picking your job. Why is your job more appealing than every single one of the $200/hour jobs in their already overflowing input box?
The schematic is sliced into 4 files: PCB 1 channel A, PCB 1 channel B, PCB 2 channel A, PCB 2 channel B. PCB 1 channel A & B is as one project file so that it can be ported as PCB 1 board design file. PCB 2 channel A & B is alsa compiled as one another project file so that it can be ported as PCB 2 board design file. This method applied to easy managing netlist and additional connection headers, also to prevent the DRC confusion if two board in a single board design file.
This is from some late-70s or early-80s mid-fi receiver or integrated amplifier?
Do you have the schematic of the original PSU? That would be an extremely helpful place to begin understanding the requirements.
I wish to pay for the service on a fixed price.
I am unsure how to answer your next two questions. I am not a major international corporation and I am sure that I am not worthy of their time. Maybe I could use this verbiage from from a famous speech: "I have a dream". In 1974 Yamaha released to the market a flagship integrated amplifier and this became the foundation that propelled them for the next fifty years. My dream is to incorporate modern technology into this unit and reintroduce it to the international market.
You do not need, and certainly cannot afford, a power supply with only nV levels of noise. Unless you really have some weird requirements that you aren't telling us about, you're better off simply buying an off-the-shelf power supply (or slightly customized, anyway) and integrating that.
These are the power supply output as needed:
+50V DC and -50V DC for main power amp VAs and input-stage/LTP,
+15V DC and -15VDC for pre-amp, 24V DC for pre-amp's relays,
+B and -B for output-stage of main power amp and some other output for protection circuit etc. Have to provide the power transformer to apply the AC source as follow:
33V AC with CT for class-B output stage operation (after passed through rectifier and filter capacitor bank, it would be about + and - 48V DC)
12V AC wifh CT for class-A operation (after passed through the rectifier and filter capacitor bank it would be about +18V DC).
42V AC for VAS and input-stage operation (after passed through rectifier, it would be about +60V DC / -50V DC and would be regulated into +50V DC / -50V DC).
Have to provide the transformer to compatible with the PSU design with those listed outputs.
15V DC + and - and power supply regulator for pre-amp and relays (24V DC) can have input from 50V DC + -
