SE 6sn7 amp....
I recently aquired a 6sl7 into 6sn7 amp & replaced the thimble sized OT's with some out of a Sony RTR, re-wired & installed a 100k pot & all the usual jack, post etc... installed it in my bi-amped OB system w. B200's & dang............this thing is wonderfull,..ran thru a bunch of my amps, to make sure..beat every one of them, including 300B , believe it or not. So now I want to build one with all nice parts. this one has small amount of hum, etc.. So does anyone have a schematic, for a amp using 6sn7 as the output in SE..? I will by top quality trannies & such, I gotta do, this thing is ugly & crazy, crazy good...I have looked all over the net, & haven't found one that was not for anything but head phones & odd OT's..If you have a idea on building one of these please let me know, so I can build it. I don't want to copy this one. I want one with better Power supply & etc.... This would be my 1st non kit build..I mod & restore, that has been about it.. time to build some.Thanks , J & G
'SN7 SE..
The SN7 wasn't normally used as an O/P tube to drive a speaker to my knowlege, so I guess schemes for it as such will be rare!
You may look around the web, for 'Micro-Power' triode schemes, that use 9 pin tubes like the ECC series, or even 5687 type schemes--maybe worth a try...
At a wild guess, its probably both sections strapped out parrallel, with the SL7 driving the grid. I reckon the +B probably around 300V maybe good for around 2-3W, not really sure.
It may be a good idea to 'reverse engineer' your existing equipment by drawing out the scheme as its built. At least then you have something to work to. The hum present is probably PSU related, or possibly layout/earth-loop issues maybe due to your mods for I/P etc.
The 'SN7 is a great and fairly neutral sounding tube, normally used for drivers and cathode-follower line-drivers etc...
The original builder sent a hand written schematic.
with unit,but some of the value's are hard to read. but I can always just get that from amp itself. Yes 300v is correct, actually I think it says 288v, & about 4w he said when fed a signal & about 2 watts with music. I stayed up way late last night listening to this & looking at all my expensive tube amp shaking my head. It really does beat them all..at that volume level which is low, but basically a normal listen level @ 9' I want to do a nice PSU with chike filter & such & use a tube rectifier. The layout of this thing is all wrong & way to tight, so I will do it correct when I do the build. amp seems dependable. & very few parts. The attraction I have to this amp is HUGE. So I definatley am going to build a proper one. Here is a pic of the ugly critter.
I like your setup
I am not a tube expert - but 6SN7 and 6DN7 looks very alike to me
Always wondered about this little "giant killer"
http://www.diyparadiso.com/6dn71.htm
BTW... doesnt Bottlehead use it too, in their SEX amp
But I guess it will need a tubepre with lots of gain
If you have the right speakers, I have found that good flea power SETs have a magical quality that eludes all other amplification. I have spent lots of time and money trying to upscale that magic to more powerful amps, with varying degrees of success.
If you have an amp that 'does the biz' in your system, I agree with Alastair's suggestion that you reverse engineer a copy and use that to experiment on. With an Rp of around 7.5k, you would be looking at opts of at least 18k. You may be able to find some nice linestage opts on ebay that offer 8 or 16 ohm outputs in addition to the 600 norm.
pm
I am new to amp tube building but have
modded & messed with them for years. I have only took up seriouse hrs & hrs per week every in the last 3 years. still have not done a complete non-kit build, but sure I can do it no problem. Cool thing is about this little SET amp is that there are NO audiophile approved parts in it,, actaually I have caps in other amps that would buy 4 of what I have into this amp. the coupling caps are ceramic disk.. pure crap in my book, & bad PS, BAD layout, trannies to close to PT etc... very sloppy wiring latout etc...& still this is the best amp @ its volume range which is much louder than you would think, I have ever heard in my life so far. I have a Scott 299b, 300B in PP, a crazy nice 6l6PP, and many others..this lil thing sucks you in like I never have encountered,..I have a SEP modded Siemens/Klangfilm mono's that are good, but they just don't have what this does. I rotated all my amps over & over again this weekend & allways the same results..So Conclusion is , that low wattage SET is for me in my low volume listening adventures, thing is also,,that I don't know if I can go back ..If you know what I mean.. I am sure many SET people encounter this,,I am just thrilled to have it. I will build another using much better parts & such, I have losta of Vitamin Q & all kinds of parts, just not many OT's or PT's . I need to stock up. The OT's I installed are rumourned to be Tamura from a Sony RTR. & I think are 5k -8ohm also with a 600ohm tap, which I have no clue what that is for.. line..? mmmmmmmmm I might try to score another set of the Sony RTR OT's, as they seem to be very fine sounding..I am soon to purchase everything from Tube Cad to help me in my adventures. these crazy low part count SET amps have something going for them.I am a big fan of simple for audio. simple seems to allways take me on the good road, complex allways take me down expensive wrong turns. Hence small SET, B200's in OB, w/NO FILTERS... only Bass augmentaion in OB @ 80hz down
How About A Schematic?
Hey JandG,
You've certainly piqued my interest--I'm a 6SN7 fan, and getting into SETs. Your amp might be perfect to run my tweeters.
Could you post a schematic? I'm hoping that the circuit is simple, and that won't be too much trouble. (batting eyes charmingly).
Oh, and I highly recommend John Broskies software. I have TubeCAD, and love it.
Best,
George
Hey JandG,
Best,
George
6SN7 is great tube...
I read somewhere that RCA stuff used some laboratory audio SE amplifier 0.7W output power with 6SN7 tube...
I think that was Olson when seting up famos RCA LC1 speaker...
The problem is output transformer, which has to be of very high prmary inductance (internal resistance of the 6SN7 is near 7K).
rough estimations is 250H... Imagine the capacitance...
Anyway, for those who want try tube shows best results at very high anode voltages near maximum of 450V...
For low-power amps maybe the better solution is 1.8W SE 10Y
amp with still demanding but less complex OT...
cheers
cheers
Bob Danielak has a paralleled 6SN7 SE amp on his web page.. though with a different input tube.
http://www.geocities.com/timessquare/1965/projects.html
6sn7 was used as a line amp but not power amp.
You'd get flea power. Enough to drive headphones only. Maybe a Lowther or a WE755. But I'm sure it would clip readily if you tried to drive any other speaker. You're looking at a 10,000 ohm primary impedance on the output transformer.
So if you used two 6SN7 bottles, you'd want 2k5 on the OPT and have 10W of plate dissipation. Not bad, similar to a 6V6 at 3k5 and 12W.Originally posted by grhughes You're looking at a 10,000 ohm primary impedance on the output transformer.
I can imagine some getting quite excited about this for a bedroom/office system or a truly awesome high efficiency setup.
The 6DN7 has the same pinout as the 6SN7 and they both were used as the vertical oscillator / output stage in TV sets, although at very different power levels. That is where the similarities end.
The 6SN7 was used in 1940's vintage TV sets with shallow deflection angles requiring low power. As TV sets got bigger, and the deflection angle got larger, more vertical amplifier power was needed. This gave us the 6BL7 and the 6BX7. These tubes are basically 6SN7's on steroids. Both triode sections are identical but capable of dissipating twice the power of a 6SN7. These were used in 1950's color TV sets up to 21 inches with a 70 degree deflection angle.
The 6DN7 (and the 6EM7, 6EA7, and 6GL7) were developed for TV sets with 90 and 110 degree deflection angles (requiring more power with linearity). The two triode sections in these tubes are NOT identical. One section is small (and similar to a 6SN7) intended for the vertical oscillator, while the other section is much larger (like a 6S4 or half of a 6BL7) intended for the vertical output stage. Similar tubes were developed that used 9 pin or compactron sockets.
All of these tubes have been succesfully used in audio applications, including the previously mentioned S.E.X. amp. All could be used to build a power amp, although the 6SN7 would be hard pressed to deliver much more than a watt. I have built amplifiers with all of the other tubes. They all sounded great, but could not deliver the sound of a TubelabSE with 45 tubes (so they were dissasembled). The tubes are however far cheaper than 45's, and could be used to build an excellent low cost amp.
Bah! I drew one a long time ago, and build something related. 12AU7s are cheaper though, and if you still think they distort, it doesn't matter in PP AB1 (AB2 ideally, but good luck squeezing much out of those high perveance 12AU7 grids).
ZNFB, so SL7 isn't needed. Yeah, I know the resistor numbers don't add up. Hmm, R4 should probably be smaller, at a glance that looks odd. Instead of plate resistors, use cathode resistors -- more typical values on the order of 100 to 470 ohms, depending on how much cathode resistor (R20) you want to make individual. Also an option: eliminate R20 and use fixed bias.
The one I built:
Fixed bias class AB1. About 1W per 12AU7. Recommend replacing drive transformer with a 6SN7 follower... drive transformers (at least cheap ones like this) suck.
Tim
The one I built:
Tim
Re: I am new to amp tube building but have
TamRadio (tamura) OPTs, 5k>8 ohms. The 600 ohm tap was used to drive the heads, could be used to make the amp a pre or to feed a sub amp (while retaininf the tube amp flavour)
Excellent OPT. I've still hot 5 stashed away (sold 3 or 4 other prs)
dave
Originally posted by JandG The OT's I installed are rumourned to be Tamura from a Sony RTR. & I think are 5k -8ohm also with a 600ohm tap, which I have no clue what that is for.. line..?
dave
Another 6sn7 SET amp..
This one is going thru a thrash at the moment,, will see.. it is very quiet..NFB 1.5w using supposed Pilot iron.I did not build this, I picked it up from a tube freak. clean build..I got it high passed & we will see..running @ 250v I think. Doesn't seem to have a great imaging, as many of my other amps do..mmmmmmm I will just have to wait & see.also how in the heck is this guy useing what probably is PP iron..???
Old thread, but wanted to confirm that 6sn7 se amps are great!
I stumbled onto this old thread and wanted to put in a word or two about my se 6sn7 amp. Mine was built by Jermey Fix, and I bought it from him on eBay about a year ago (2009).
With a decently hot preamp in front of it, in my case a Minimax, this thing is amazing! Bass is slightly shy but the imaging is so good it is wonderful.
I've put it up against three 300b amps of various makes, a nice 45 amp with western electric outputs and various el-84 and t-amps and this little one watt wonder bests them all in imaging and "you are there" palpability.
Single ended 6sn7 really is worth looking at.
I agree with you kunja. I'm using GE 6SN7GTB tubes (higher max. dissipation)
with a PP 1609 10K Hammond OT. I'm using the 4 ohm tap with an 8 ohms speaker so the tube sees 20K.
370 volts, 15 mA current. A sound I've never heard before. Problem is that it clips, needs a 100dB speaker. Better than 45's and 2a3 amps.
Best SE amp.
Best SE amp.
- Tubes / Valves
- SE 6SN7 amp....
