sc350w
edl said:
Dear PM650,
a better realization attached.
Best regards,
Fully version attached,
200W-RMS/4ohm, d<0,1%, 10Hz-30KHz
Re: Re: Aaah this one..
lineup said:
Most work to trim and tweak was obviously done in 1989.
Silicon Chip two articles was in 2004, published by 2 authors.
As Silicon Chip and Electronics Australia Magazine both are magazines from Australia,
I guess eventual copyright has been cleared.
Aaaah back from fishing.
I was talking about posting the artwork layouts froom the website. The SC layouts are indeed copyright.
The fish & squid & crabs were delicious.
PM650 said:
This is a bit off topic, but I would be curious to know anyones comments on this amp schem compared to the Studio 350:
http://www.mustangmods.com/data/2197/amp_schematic.jpg
The reason I'm asking is the amp can be purchased in kit form very cheap ($30) with heatsink, and it seems to be similar to the 350 at a glance.
Let's buy the kitset, and upgrade that this way.
The offset circut can be cancelled, if the DC-offset in the output isn't bigger than +/-100mV.
It will give you 200W-RMS on 4ohm.
the amp is firstly designed for MJ15003/MJ15004 output transistors. If I use 2SC5200/2SA1943, the currents could be lower, because the 2sc/2sa pair has higher gain.
Anyway the circut works fine with 2sa/2sc outputs too, but 2×12mA current in the second diffamp is unnecessary. We can use only for example 2×6mA, and than the MJE340/350 transistors shouldn't be heatsinked.
This design is not the state of art, but as I wrote, for PA purpouse its enough.
But we can keep the currents higher, with heatsinked MJE trans'. Higher current here means better quality.
If the offset isn't bigger than +/-100mV (in the most cases it not higher, but I don't matching the transistors, so it can be), the 100k resistor (that goes from the offset-circut to the input) need to be eliminated, because offset adjust is unnecessary.
hello guys
seen this studio 350 and since i like so much simple constructions i wonder if i can get any more information specified about this amp .....
i ve been reading the post through ....and my applications are small pa application where power stability and capabilty on working 100% of power for many hours is the target ( often above quality )
supposed that the rest of the construction is perfect (proper trafo , caps , softstarts cooling ,ground loops and goes on ) is correct do you recoment this amp to my applications ???
thank you sakis....
sc350
The Studio 350 is 200W/Ch. 8 ohms and 350W/Ch. 4 ohms
Electronics Australia no longer exists. EA copyright is now owned by Silicon Chip, who also have their back issue articles.
The Studio 350 is streets ahead of those old EA designs.
Carlos, surely you are joking about any modern amplifier with any pretensions to quality, using those slow and antiquated 2N3055/2N2955 ?
Sandyk
