SB Bromo kit Port dimensions?
Hey guys, I am in the process of building the Bromo kit from SB and I cannot find the port dimensions anywhere!
There are none mentioned in the kit info except that the cutout should be 73mm.
Madisounds site for the Bromr kit says 2in. dia. and either 6 or 7 inches long....
Can anyone help me to find the right info?
I dont want to cut holes without knowing for sure what the proper size is.....
Thanks!!!
Thanks!!!
I used 50mm diameter pipe, lenght was around 20cm. You have to tune it to desired frequency with nearfield measurement of woofer. Find minimum motion, thats your port tuning frequency.
@mctavish @DarkOne
How does the BROMO sound? Any comparision with other DIY builds or commercial speakers?
Bromo sounds quite good, but a bit "soft on midrange", vertical off-axis also is not optimal there. It lead to new build with same drivers and new crossover:
SB Acoustics EKA Ceramic Kit by StereoArt
Attached image: Red on the graph is original Bromo, green is EKA Ceramic by StereoArt. Unfortunately while measure mic calibration was not loaded (take off @10K about 1-2dB).
You may compare EKA Ceramic by StereoArt to Marten Oscar Duo - about same SB Ceramic drivers, but DIY sound better and measures better then 7000$ Marten
