I'll turn it on with a long stick, don't worry ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
seriously though, what''s wrong with that? seems to make sense according to this diagram:
http://www.diyaudio.com/forums/attachment.php?s=&postid=1517796&stamp=1211507098
Seriously, you had better read up on using electricity safely and particularly the colour codes we use in the UK.
Brn = Live
Blu = Neutral
Grn/Yel = Earth.
Older wiring often uses
Red = Live
Black = Neutral
Grn = Earth
Go and find a friendly electrician and ask for some safety guidelines.
Go back to your Physics/Science/CDT teachers and ask them.
Seek help before you injure yourself or someone else.
Brn = Live
Blu = Neutral
Grn/Yel = Earth.
Red = Live
Black = Neutral
Grn = Earth
AndrewT said:Seriously, you had better read up on using electricity safely and particularly the colour codes we use in the UK.
Brn = Live
Blu = Neutral
Grn/Yel = Earth.
Red = Live
Black = Neutral
Grn = Earth
you worry too much
can anyone tell this guy how to kill himself. He doesn't believe me.KieranC said:....besides, it's an alternating current, surely you could hook live/neutral up either way and have it work?
I wonder if that is his last post?
AndrewT said:can anyone tell this guy how to kill himself. He doesn't believe me.
Yes, I'm posting from the grave, I decided to test the mains lead with my tongue.
How stupid do you think I am?
Thanks Puffin. It's sounding good
Sashi said:^^ How did it taste?![]()
A lot like chicken...
Connecting Live and Neutral the wrong way round will not kill you. In many countries the mains connectors allow for turning them by 180°. There you never know, on which side it is Live or Neutral. As long as your PE is done correctly, have no fear.
However, if you live in the UK, where Live and Neutral have a determined position, you must absolutely stick with it. Take into consideration that there is always the possibility, how unlikely it may seem to you, that someone else opens up your amplifier and relying on his experience touches, where he usually could, but in your amp should not.![hot :hot: :hot:](https://files.diyaudio.com/forums/images/smilies/hot.gif)
Puffin said:You've got your wires crossed. It should never taste like Chicken!![]()
Oh no!
Thanks for all the info, as much as I joke I'm always very careful with electricity, hence all the questions.
I think a pre-amp will be my next project, even with the CD player on minimum volume this is rather loud
I found a 2 input selector switch thingy on ebay for about £3 so I bought it and fitted my old volume pot inline with the output... seems to do the job! apparently the pot works best with a ground connected
next step, internalize it!
- Chip Amps
- Sanity check - mad about sound lm3886 stereo amp build
