Sanity check differential amplifier for DAC
@Chris Hornbeck thanks for the feedback, the actual value if the I/V resistor is still to be decided. A higher value gives more amplification, so that's something I'll investigate. Perhaps I need to switch to a 6SL7 and 12SL7 to have more amplification so I can lower the resistor.
@Merlinb, thanks for the input I'll have a look at a CSS instead, popping the grids wasn't the intentions. Also, I'll look up the use of diodes in your book (got a physical copy 🙂 )
