Salas L Adapter circuit on Raspberry Pi footprint Board
I made some Salas L adapter circuits on placed them on a raspberry pi board outline for my music servers that run Moode Audio. I have made some new ones with a changed component footprint positioning to better suit the other boards in my stack, So the old ones are for sale if anyone is interested. I will list them as I swap out my old ones.
The 2 white connectors supply 5VDC. one has a ptc fuse on it. My Pi running Moode only drew about 500mA. If you were drawing more you might need a bigger heatsink. It was supplied by 9v dc by an old linear wall pack. It has a toggle switch on the 9v input for off and on.
Thanks. On that one I first powered the Pi by running 2 connections from under the board where the 5v jack was to the IO to power the pi. I fitted the jack on top of the board later. My other ones power the PI through a header mounted on the board but that is a different layout. As you would know if you power the pi through the IO you dont have some of the protection. I will post some pics later.
