Thanks Jean-Paul. I guess I was lucky with the leds buying 30 from Farnell with most of them giving 1.8v give or take 0.04-5v with a few above 1.9 and acouple below 1.7. I'm really looking forward to listening to this; then I'll have to decide on a case. Maybe Hifi 2000.
Keith
Keith
Its because the blue has a differently connected positive leds local CCS. Orthodox connection. Goes OK tonally when hot rod as the blue is intended. The black boards have an inherent twist to present a certain tone when run ecologically as originally designed. That will make them slightly asymmetric on purpose. (+/-) 9.5 to 10.5V is my preferred sweet spot, so the mentioned build seems perfectly OK.
Of course ! I have the old Mez version and not the hot rodded blue version, sorry. While I am building a new Mez this evening I was searching the forum for posts regarding the voltages when I ended up in this thread. The third Mez has larger differences than the others which I wanted to check.
I was not aware that there are differences in the schematic of the blue version though...
Should a pot go before or after the DCB1? Opinions please...
I note that on the Mez it is before. It could be either way though, couldn't it? I'm sure the result will be different, but both should work...which is best?
Before is the best way. Why would you make the output impedance higher by adding a potentiometer there ? And the circuit will be more noisy as it is always "open" at the input...
OK, before then. Thanks.
On the subject of pre-amp earthing. What do you think to my suggestion to isolate signal earths through the pre-amp process, so that they only reach earth in the power amp? Is this a good procedure? It reduces the likelihood of earth loops, no? Is there any reason not to do this?
Please only use the term "earth" only for PE/Safety Earth which is meant for safety in case of live AC wiring touching the chassis/case. There is no "signal earth". I know that the terms are very misleading as we speak about "ground loops" in english... I recently read a very good explanation regarding safety earth/PE and signal GND on this forum but I don't recall in what thread it was.
You mean signal ground or GND, don't you ? Or safety earth/PE ?
I have posted that will be a difference there when there was talk about releasing it, it shows on its CCT too if you look 1st page here. Also for reg only I have put a note on the reg only thread not to manipulate that fet as for the black. Then again the threads were galloping, easy to skip info. Check your positive side jfet leds ccs (the one connected to the 10R) maybe its stronger than average, or some leds on that side are a bit happy.
Sorry, yes I mean signal return. It does terminate at the earth, and so yes you're right it's important to be as clear as possible. I mean the return that runs with the signal lead through the RCAs and interconnects.
My question is whether it is really necessary to connect them to transformer earth/chassis earth within the preamp, as is performed on the DCB1 blue with jumper number 2?
Is there a good reason to connect the signal returns to earth, or is it better to leave them isolated from the chassis and electrical system until the power amp? My thinking is that a loop is created when signal returns are connected to earth on both pre and power amps.
Many thanks
Lucas
Its a system grounding thing as in any. You just need to avoid loops and be quiet. You apply your best strategy you are experienced with.
That is a political correct answer Salas 😉 But it is too late for a complete reply now, I am off to bed.
Well, if I am honest, I've never had a fully silent amp, since I started DIYaudio. 😱
I intend to put that behind me with this build.
Anybody?
http://www.diyaudio.com/forums/diya...udio-component-grounding-interconnection.html
Lucas,
In the "Articles" section at the top of the page is an article on grounds.
I hope it helps you.
Hi, I guess you built stereo amps with 2 supplies and only one transformer didn't you ? Hard to get quiet.
Isn't a stereo amp with a solitary twin-secondary transformer feeding two bridges a good way to build an amp? It works for Nelson Pass...
No, my problem has always been in preamp grounding and integration between units.
agreed.Hi, I guess you built stereo amps with 2 supplies and only one transformer didn't you ? Hard to get quiet.
Monoblocks are relatively easy to get quiet.
4x matched 2sk170 plus 6x unmatched. All BL grade.
Preferred 7-8mA matched quad, but any BL is OK.
Oh, plus BC550s + BC560
- Analog Line Level
- Salas hotrodded blue DCB1 build
