It lives at the first attempt! Music coming from my lash up rig via an old Yamaha AV amp, some 20 year old Denon speakers and a CD player that is older than my daughter who's 22! Maybe tomorrow I'll jump right in and connect it to my main rig, cont foresee any problems but I'll leave it playing on repeat all night so it gets a bit of a burn in. Thanks Salas.
I now have the DCG3 hooked up to my main system, it’s super quiet, not a bit of hiss or hum from the speakers. I do however have a pretty major problem, I have just got waaaaaaaaaaayyyyyyyyyyyyy too much gain! I’m currently using just the power amp section of my Perreaux Eloquence 250i and I can use to about 8 o’clock on the pot and it’s very loud. Checked the manual and I have 28.8dB of gain in the power amp - how low can I take the gain on the dcg3 (currently set to 3 with a 1k) without causing any issues?. Long term plan is to get a different amp but what’s the best approach to reduce the gain in the time being?
You can hang a resistor from the source input to the potentiometer input. Choose R same as volume potentiometer. This creates sort of a virtual potentiometer with double the input resistance and only half way can be put out via the wiper ( middle pin). The virtual pot turns only half while your knob turns full. And easily reversible too[emoji106]
Although an input voltage divider is possible, it's better to fix the gain lower via R6. Not to narrow the bandwidth with inevitably higher source impedance. Since this circuit isn't input buffered. Can go down to 500R R6 as mentioned. The amplifier's gain is high enough, maybe the speakers are sensitive enough also? Anyways, when in a loud combination the background is still reported quiet after adding 3x, that surely points to a good preamp build.
I'll try and source some Dale 499 ohm in the UK to lower the gain. A quick google pops these up, Salas can you confirm these are what I need? Vishay Dale CMF55 resistor 1% 50ppm 499ohm - Audiophonics
I also have 4 BC327-40 all with 499-502 hfe so I'll pop them in as well.
- Analog Line Level
- Salas DCG3 preamp (line & headphone)
