I am having an issue with my DCG3 build.
One channel is up and working perfectly the other is measuring +16.9V offset!!
The DN2540 CCs is measuring 120mA and the BF256B CCS is measuring at 5mA (both exactly the same as the working channel).
I can see no obvious poor joints or incorrect resistors or transistor orientations. Any thoughts on the best way to find and rectify the issue?
Ian
Ian
Check the bad channel's Mosfet tabs insulation to sink / chassis is good first. The DMM's continuity buzzer will tell.
Hi I did check and indeed just checked again and there is definitely no short through the MOSFET tabs
Ian
Ian
OK,
Big difference here.
The good channel has a VGS of approx 4.51V for both M1 and M2.
The bad channel has 12.6V on M2 and 8.23V on M1.
Probably finished parts (static shock?)
But also check voltages around the Q1 Q2 BCs vs the good channel in case they are problematic.
On the good channel:
Q1 VBE = 644mV, Q2 VBE = 0mV
On the bad channel
Q1 VBE 7.58V, Q2 VBE = 630mV
On the bad channel
By the way, good opportunity to install female pins for those two. So to can put and compare BC327-40s at a point which tend to promote a more realistic sound in this preamp according to the builders subjective majority vote.
Change Q1?
Though I need to check the hFE for both I guess?
Just to know if it's the culprit or not, hfe match doesn't matter.
Hi I just replaced the BC560's with BC327's and on powerup, I got exactly the same result with huge offset and weird vbE readings on the BC327's.
Would the next logical step be to replace the IRF9610's and replace the BC327's again?
- Analog Line Level
- Salas DCG3 preamp (line & headphone)
