It may seem a little strange question to ask, but is it as easy as a resistor and an LED?
I'm wanting to get toslink output available on my car pc, but it currently only has s/pdif. I've seen a few sites saying just a red led and a 100-120ohm r is fine.
If you google torx all your questions should be answered. Toslink transmitters require the SPDIF signal at TTL or CMOS voltage level. Standard SPDIF output level is only 0.5V. I've never tried the red led trick, go for it.
Thats great. The question is now, how do i raise 'standard' spdif to TTL level?
Torx has shown answers for the opposite conversion (optical to spdif) but none so far for the other way.
Would something like this be suitable?
After some more searching and fiddling i found that the source was converted from ttl to spdif.
So I will just tap off prior to this source and attach a red LED and resistor and try it.
I'll post up my findings 🙂
Aha, got it now.
That could be even easier for me then, so long as the vcc is clean (computer powersupply
Thanks 🙂
Thanks 🙂
- Digital Line Level
- S/PDIF to toslink
