This is all that Google had. Perhaps others know.
6x9 Speaker 30 W (400-1265) Specifications Faxback Doc. # 14326
Voice Coil Imp:..............................................8 ohm +/- 15%
Frequency Range:...........................................fo C/S- 16 KC/S
Resonant Frequency:......................................70 C/S +/- 10 C/S
Normal Power:...................................................12 W (RMS)
Sensitivity:..............93 dB +/- 2 dB Mean value at 0.3/0.4/0.5/0.6 Khz
Response Deviation:..................................................20 dB
Total Flux:........................................................Maxwell
Flux Density:........................................................Gause
Magnet:
Material:.......................................................Ferrite
Weight:..........................................................9.8 oz
Weight:...............................................................805g
28.44 oz
Operation:..................................................Must be normal
Busses Rattle:..............................................Must be normal
(ALL-03/22/95)
Magnet:
28.44 oz
(ALL-03/22/95)
thanks for the replies cal, kelticwizard.
those are also the same specs i got from the radio shack site.
was hoping to get the t/s parameters though.
you guys think this would make a decent mltqwt project? or should i relegate it to the dustbin?
thanks in advance for your inputs.
cheers!
cheers!
By any chance, do you have a calibrated microphone or a radio shack SPL meter?
Because if you do, there are charts which have correction factors for the various Radio Shack SPL meter models. With that and a freeware tone generator available online, you can measure Qts, Fs very easily. Vas can be measured with a small box.
Freeware tone generator:
www.satsignal.net => Audio Tools => SweepGen
Nenoshi and Jayqjay:
On your computers, do each of you have a sound card with a SPEAKER OUT-that is, a sound card that can drive a set of speakers directly? Or do you require an intermediate amp to drive a set of 8 ohm speakers?
Some sound cards have that SPEAKER OUT capability-mine has 4 watts into 8 ohms-but other sound cards do not. Which one are each of you?
Because I plan on posting some quick-and-dirty ways to measure some Thiele-Small measurments-a little easier than the conventional ways. But I have to know if your sound card has the capability to drive 8 ohm speakers directly.
hi kw, sorry for the confusion buy nenoshi and jaygjay are one and the same person
(a case of a misplaced password).
i've only tried using computer speakers on my pc (no experience using hi-fi speakers with it yet).
if it's gonna be any help, i'm attaching the settings of my sound card (just in case it might help determine if my sound card has that capability.
thanks a lot!
thanks a lot!
- RS driver help
