Rotel RB 1090 power switch sticky
No I didnt verify it. It was 7 dollars. I figured I would get it. Couldn't hurt to have it on hand. The switch is another thing. I don't mind purchasing these items. If it's something else entirely, I will cross that bridge...Now I need to find a tech in the Phoenix AZ area.
Reactions: BSST
Hello, I wanted to thank everyone who provided me with suggestions and advice. The nicest thing was that everyone was very kind and patient with a novice. That is not so common. An update on the amplifier. I picked it up yesterday. After checking around I brought it to High End Repair in Phoenix. James with his one man operation repaired and or replaced the power switch, a relay, thermister, capacitor and a transistor. He also found an issue unrelated to the switch that could have caused a problem down the road. I do remember seeing one area with a 2x2 inch clear plastic covering a small circuit board which was discolored and browned as if over heated. That was not normal apparently. I thought it was just due to age. He checked the bias and adjusted the offset. 200.00 which I think was very fair although I have no idea what something like this should have cost. I was happy to pay the cost and now the amp is singing again. Thanks again!
Reactions: chrisng
