Rogers A100
Hi there, I am currentlly ripping apart a Rogers A100 class B 55 watt per channel amplifier to use it's power amp sections as monoblocks. I will be using a seperate power supply for each that should help boost the wattage and it's ability. It uses some form of current dumping so runs nice and cool when quiet.
I was wondering if anyone had any information on the Rogers A100, about it's designs etc.
Just about the only integrated i'm aware of that uses the amp's back panel as a heatsink.
2 Motorola TO3 output devices per channel, about 5 watts in Class A would be more truthfull.
