Rockford Prime R600x5
Here are some pictures that I took
I don't see anything definitive or familiar. The only way to find the break in the signal would be to drive a single channel at a time and map out the output pins of the op-amps that have signal for each channel. You'd do this in full range mode.
I'd suggest that you make something similar to the attached image (fine tipped dental probe used as a meter probe) to prevent shorting between pins, especially when probing pin 7 (output pins of the ICs are 1 and 7 for the njm2068 op-amps).
Perry,
So far this is what I got. Pin 7 is hard to get to one these because the input board sits on top of these and I dont want to short anything out like you said. If these reads dont help I will try to get pin 7.
u4- pin1 0.800
u5- pin1 0.142
u6- pin1 0.328
u7- pin1 0.762
u8- pin1 0.800
u9- pin1 0.968
u21- pin1 0.776
You don't need to post the voltages at this point. What you're trying to do is find the output pins that correspond to the various channels.
Make sure that there is no audio from the (good) channels, other than the one you are driving. If you're getting near 1v on the driven channel, I'd expect less than 1/10th of a volt on the non-driven channels.
