There is no single reading that you'll look for. Ideally, there will essentially be no AC voltage on any of the op-amp output pins until a signal is driven into the amp. Then, when you drive a sine wave into one channel, only that channel should have a signal. The readings will depend on the input drive level.
- General Interest
- Car Audio
- Rockford Prime R600x5
