Rockford Fosgate T30001bd
You're losing drive because there's too much DC offset. That may indicate that there is some leakage in the output stage (contamination, leaky output).
Did you try inserting a 120v lamp in the rail supply lines to see if it would more fully power up?
You can try the lamp in the speaker terminals as well. It will be a load but a much lighter load that may allow the amp to power up.
Rockford 30001 FET soldering
Wow, by sheer coincidence I was surfing for info on a 30001 and found a post from 2 days ago.
I love this forum.
Short of buying a reflow oven, any suggestions on un/soldering output and supply FETs from the boards.
Jim
I placed a 120v light bulb across outputs and amp still did the same thing rail voltage up to 110v on 2 banks and the amp trips protect voltage drops to about 55 and back up to 110v. The amp continuously does this. Maybe I damaged one the outputs heating the mesha board too long at 450 with hot air from the bottom. Not sure I did notice that 2 banks would intermittently on diode check at 0.255 and then sometimes would diode check at 0.475v. This was teste with both driver circuits removed. But can’t verify that theory with old pulling the mesha boards.
