P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 3:34 am #21 2022-02-20 3:34 am #21 Solder a bridge across R315. What do you see on pin 7 of U301 and U302? C caraudioguy2100 Member Joined 2010 2022-02-20 3:47 am #22 2022-02-20 3:47 am #22 After soldering a bridge across R315 this is what I get on pin 7 of both ic’s scope set to .2ms .2volts/div Attachments D8C1A4F9-4A79-451E-B77F-FCB7C29D07C1.jpeg 459 KB · Views: 47 P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 3:50 am #23 2022-02-20 3:50 am #23 Set the timebase to 10us. Is the probe on 1x or 10x? C caraudioguy2100 Member Joined 2010 2022-02-20 3:54 am #24 2022-02-20 3:54 am #24 Probe is set to 10x here is what I get when set to 10us Attachments 50BFA2EB-B8AB-444F-92BC-A2F26241CEDC.jpeg 499.3 KB · Views: 59 P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 4:00 am #25 2022-02-20 4:00 am #25 What do you see on the gates of the rail switching FETs? C caraudioguy2100 Member Joined 2010 2022-02-20 4:05 am #26 2022-02-20 4:05 am #26 On the outputs I get the following 2 signals on the gates scope set to 10us 2volts Div . Attachments D9675736-5888-4B45-8F23-84F34E660042.jpeg 500.1 KB · Views: 47 520EEB9C-B28B-4779-A01E-4444057BC423.jpeg 466.6 KB · Views: 51 P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 4:09 am #27 2022-02-20 4:09 am #27 What's the DC voltage on pin 3 of the 3706 driver ICs? C caraudioguy2100 Member Joined 2010 2022-02-20 4:10 am #28 2022-02-20 4:10 am #28 5.44 on both P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 4:12 am #29 2022-02-20 4:12 am #29 Which pins of those ICs do you see a square wave? C caraudioguy2100 Member Joined 2010 2022-02-20 4:17 am #30 2022-02-20 4:17 am #30 Pin 1,6,11,16 on U400 Pin 1,16 on U401 P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 4:32 am #31 2022-02-20 4:32 am #31 Do you still have signal on pin 7 of U301? C caraudioguy2100 Member Joined 2010 2022-02-20 4:38 am #32 2022-02-20 4:38 am #32 Pin 7 of 301 I get a square wave P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 4:42 am #33 2022-02-20 4:42 am #33 Re-check pins 2, 6 and 11 on U401. C caraudioguy2100 Member Joined 2010 2022-02-20 4:50 am #34 2022-02-20 4:50 am #34 I do not get a square wave on pins 2,6,11 of U401 P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 4:54 am #35 2022-02-20 4:54 am #35 What about pin 2 of U400? C caraudioguy2100 Member Joined 2010 2022-02-20 4:55 am #36 2022-02-20 4:55 am #36 No P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 4:58 am #37 2022-02-20 4:58 am #37 On resistors R309 and R322, do you have a square wave on one end but nothing on the other end? C caraudioguy2100 Member Joined 2010 2022-02-20 5:02 am #38 2022-02-20 5:02 am #38 I do not get square waves on either one of them both sides have no square wave P Perry Babin Member Joined 2003 bcae1.com 2022-02-20 5:03 am #39 2022-02-20 5:03 am #39 Didn't you have a square wave on pin 7 of both U301 and U302? C caraudioguy2100 Member Joined 2010 2022-02-20 5:07 am #40 2022-02-20 5:07 am #40 I had a square wave but now it’s gone Prev 1 2 3 4 Next First Prev 2 of 4 Go to page Go Next Last You must log in or register to reply here. Share: Facebook X (Twitter) LinkedIn Reddit Pinterest Tumblr WhatsApp Email Link Home General Interest Car Audio Rockford Fosgate T20001bd Top Bottom
