DCv on U202, pin 2?
With a triangle wave on one input and 0v DC on the other input of the same op-amp should result in a clean square wave on the op-amp output.
¿DCv en U202, patilla 2?
Con una onda triangular en una entrada y 0v CC en la otra entrada del mismo amplificador operacional, debería dar como resultado una onda cuadrada limpia en la salida del amplificador operacional.
If you bridge the cap C48 in the power supply section, do you see a difference on U202. pin 2?
If you lift/remove R232 and R246, do you get a square wave on pin 7 of U200 and U203?
I don't know, but look what I get out of removing the R226 and R240. pin 6 and 11 of u202 and u204 already both work
it seems that we already achieved that both u202 and u204 will oscillate,what else would be needed?
- General Interest
- Car Audio
- Rockford fosgate T10001bd output stage damage
