There is no drive on the power supply mosfets now. There's is only low voltage on the regulators. Even with b+
U1
1. 10.15
2. 10.95
3. 10.34
U2
1. 1.895
2. .489
3. 1.996
From left to right. Replaced the 22r resistors they didn't burn again after I removed the 594 from the no drive at the chip. Something happened to the 594. Anyway I just replaced it and drive is back. No b+ remote and ground only
U1
1. 10.15
2. 10.95
3. 10.34
U2
1. 1.895
2. .489
3. 1.996
No change in current it seems fine. The ic shorted, I believe the power supply remote wire hit a speaker terminal. Whatever reason the ic was not producing any drive. Replaced it and the amplifier had drive so then with a small fuse in line 5amp tested the b+. Amplifier powered up and the 22R resistors did not burn..
- General Interest
- Car Audio
- Rockford Fosgate Punch 400.4 trans•ana
