Hey I have a 240x4 with one channel that emits distorted audio. It'll play but push the cone audio out to the beat and have distortion like staticky. I replace IRF540 and IRF9540 as well as source resistors and gate resistors. Channel won't bias either. I did the same with the right channel only 3 channels work properly. Any ideas what to check?
Drive a 50-100hz signal into it and post a photo of the waveform. Do this with a speaker/dummy load connected.
I found the problem. It a was an smd transistor in the protection circuit that was shorted. Amp works great now.
Hello. Do any of you have the schematic for this amp. I'm trying to repair mine.
Thanks for any help..
Please don't post in a repair thread that was started by someone else unless you are trying to help them.
Start a new thread. Post the PC# from the board in your amp
Sorry I'm new. Won't happen again.Please don't post in a repair thread that was started by someone else unless you are trying to help them.
