Can anyone tell me the value of R157 and R257? They are very burnt and I can't read the color codes.
Ok stay with me this amp seems to be a basket case.
Rebuilt power supply and all is well with that.
4 new IRF3205's, 4 new 47ohm gates, 4 new driver transistors. Amp powers up fine and idles.
L&R channels have recieved all new output fets, all new gate drives, and all new emitter resistors.
R157 and R257 have been replaced.
LM339 reads as follows:
pin 1: 4.41 vdc
pin 2: 4.41 vdc
pin 3: 17.87 vdc
pin 4: 0.188 vdc
pin 5: 2.995 vdc
pin 6: 4.34 vdc
pin 7: 4.99 vdc
pin 8: 4.67 vdc
pin 9: 2.916 vdc
pin10: 4.99 vdc
pin11: 8.21 vdc
pin12: 0.002 vdc
pin13: 4.39 vdc
pin14: 0.080 vdc
Amp produces 75.5vdc rail voltage and all op-amps have -16/+16 vdc on supply pins.
L+ bridging terminal has 16.5 vdc
R- bridging terminal has -2 vdc and bleeds down fast
The left channel wont bias and is very distorted, and the right channel has audio but tries to bias as soon as you try and turn the pot at all.
Q242, Q244, Q245 all have no rail voltage and have +37 vdc on their drains.
243, Q246, Q247 have rail voltage and have -1.950 vdc on their drains and bleeding down fast.
Q143, Q146, Q147 have rail voltage and all have +15 vdc on their drains.
Q142, Q144, Q145 have 1/2 rail voltage and all have +37 vdc on their drains.
I know this is alot of info but thought someone could kick it around looking at a schematic and maybe point me in the right direction to start.
pin 1: 4.41 vdc
pin 2: 4.41 vdc
pin 3: 17.87 vdc
pin 4: 0.188 vdc
pin 5: 2.995 vdc
pin 6: 4.34 vdc
pin 7: 4.99 vdc
pin 8: 4.67 vdc
pin 9: 2.916 vdc
pin10: 4.99 vdc
pin11: 8.21 vdc
pin12: 0.002 vdc
pin13: 4.39 vdc
pin14: 0.080 vdc
Let's start with the 200-series channel.
Are you saying that the source legs of Q243 has no rail voltage?
Q242, Q244, Q245 source legs have no rail voltage.
Q243, Q246, Q247 source legs have rail voltage.
Post the voltage on all three terminals of the following transistors. Place the black meter probe on one of the non-bridging speaker terminals. Place the red meter probe on the point where you need to measure the voltage.
Q128
B:
C:
E:
Q129
B:
C:
E:
Q118
B:
C:
E:
Q119
B:
C:
E:
Q128
B:
C:
E:
Q129
B:
C:
E:
Q118
B:
C:
E:
Q119
B:
C:
E:
Q128
B: -30.75 vdc
C: 0.000 vdc
E: -37.40 vdc
Q129
B: -32 vdc
C: -37.41 vdc
E: -37.41 vdc
Q118
B: +17.10 vdc
C: +75.2 vdc
E: +18.73 vdc
Q119
B: +16.70 vdc
C: +15.15 vdc
E: +17.00 vdc
That should have been the 200 series parts... but, Q129 looks like it may be shorted.
Post the voltage for the 200 series parts next.
Q228
B: -34.20 vdc
C: 0.000 vdc
E: -34.72 vdc
Q229
B: -35.36 vdc
C: -37.41 vdc
E: -34.81 vdc
Q218
B: -4.09 vdc
C: +75.2 vdc
E: +1.800 vdc
Q219
B: -4.75 vdc
C: -0.860 vdc
E: +1.950 vdc
In the 100 series channel I found R140 and R170 to be way out of tolerance. These 2 are 33 ohm resistors. I replaced them and now the amp wont power up goes into full short and current draw on my power supply.
Any thoughts on why that is?
Changed Q119 and Q118.
After those I powered up and Q117 and D103 blew.
Changed Q117 and D103 now amp powers up and idles with same issue of 17 vdc on bridging terminal of left channel.
I feel I have made no progress changing out the 2 bad resistors R140 and R170.
After I power the amp up the current draw jumps up a little and I hear like a hissing noise or frequency noise from something in that channel.
I dont know what to think?????
Let's deal with one channel at a time. If the 100 series channel is causing problems, pull the outputs. Does that allow the amp to power up?
Lift Q226 and Q230. Be careful, it may draw excessive current.
If you have any other components out of the circuit in this channel, reinstall them.
- General Interest
- Car Audio
- Rockford Fosgate Punch 200IX
