Rockford Fosgate Power T2500-1bd
Hi, working on a RF Power T2500-1bd. Power supply is running. No shorts in the outputs. I have +142V rail. I don't have the minus rail voltage. I have 160 AC to both negative rail diodes CR2 and CR1005 but +24 v on the cathodes. I pulled all the outputs just to make sure they weren't a problem. Anyone familiar with this amp that can give me some ideas. Called Rockford. Schematic not available.
Anyone familiar enough with this amp to answer a question for me. I think the amp is muted. I have what looks to be input on pins 2 and 4 of U2000 and U2002 but no output on pins 5 and 7. I have 6.8 volts on pin 8 of both chips. I believe this to be bd mute. I'm using a schematic for a Power T5001bd. Can't find where bd mute originates. Can anyone help?
"On that diagram, U4-D is the mute output." Yes found it on the amp power supply driver board. U101
"Do you have all of the various supply voltages?" I have rail voltage. +/- 15 volts. The schematic shows regulators for various voltages. I don't see regulators on this board. So I don't know about the other voltages.
"Do you have audio reaching the output driver board?" Yes
"Do you have rail-rail oscillation on the output transistors?" Please explain how to check rail to rail oscillation with only one rail.
The pics are with no signal in.
Aren't the audio driver ICs U2000 and U2002. They drive the transformers. I have a nice square wave on pins 2 & 4 of U2000. But nothing on the outputs pin 5 & 7. I have a lessor not as nice square wave on the input pins 2 & 4. But nothing on the output pins 5 & 7. I have 6V on pin 8 muting the outputs. Sorry if this isn't what you were asking.
