rockford fosgate power 1001 bd
If you flip the 0/180 switch to the other position, does the voltage on 5, 6 and 7 drop to very near 0v? The voltages look OK but I'm curious about the 0.v of offset.
If you only have 8v on the speaker terminals, recheck the voltage on U17. Re-post the voltages if they've changed significantly.
What is the DC voltage on pin 7 of U11?
Thanks Sean and Perry for your help I got the parts today and now the amp powers up fine but resistor r44 gets hot and the output is all static. here is the voltage for the U17
1: 0
2: when i touch the positive probe the amp starts to squeal.
3:.007
4: -962
5: 0
6: 8.38
7: 9.38
8: 0
In the previous post where you listed the voltages on U17. The voltage on pin 4 wasn't right. It should have been near -10v. Re-check the voltage on that pin.
Also, with 8v+ on pin 6, I'd expect to see significant voltage on the speaker terminals unless the amp was in protect mode. Was the amp in protect mode?
You could have a bad opto-coupler or a bad driver.
The driver: MIC4420CT
The coupler: HPCL 2211
Sometimes when DC is out of wack in an amp it can blow other components in the circuit.
Do you have a scope?
I didnt see R44 in the schematic??
Can you post a pic?
Take a pic and download it to your computer.
Post, then scroll down to manage attatchments and click on it.
A box will open, then click browse.
Find the picture in your computer and double click it.
Then click upload.
Once the picture is uploaded you will see it under the manage attatchments link.
The submit reply.
OK Sean here is the voltage's
u5 U15 U6
1: 0 1: 0 1: -9.59
2: 8.33 2: -4.04 2: -9.59
3: 8.26 3: -3.41 3: 9.84
4: -9.61 4: 0 4: -9.59
5: 0 5: -9.61 5: -8.98
6: -7.32 6: 0
7: 9.83 7: -9.08
8: 0 8: 9.83
R44 is standing up next to the transformer.
