Rockford Fosgate p1000x2
So I started on a new amp today. And it had a few shorted components. 2 outputs., And two source resistors. Same koa 3watt 0.01ohm...?? Anyway the amp runs irf3415 and irf6218 -120v 27amp replaced the bank of 3415s and waiting for the other outputs. Ps is running. When I test the 3415's the new ones I got a diode reading across 1-3 of .568 and nothing on the forth (in the slot of the shorted one) any ideas what I should check. I been checking non, an pnp drivers through out the board and resistors for anything open or out of tolerence?
I'll test them again. All of them tested open. OL is all I got no resistence a to all.
Yes in ohm auto range.
Would it be drivers, there were some out 10R0 burnt. On the left channel. I'll test all legs and post what I get on all outputs.
Ok so I hooked it up and got 12.5v and only drew a small amount of current. Seemed like the ps fets we're faulty I'm.bot sure the driver's test good. I'll test the 494 pins 3-4 for voltage and see if it's high, maybe it's shutting off and on? Or should I just remove the retifiers and get the paperwork up and running isolated? mosfets Irf1404z
