I can't get a drive signal for the power supply. Replaced drivers and tl494. Is it in protection? If so how can I take it out remove d1?
I'm not sure if you can get a drive signal without the rectifiers in place.
I don't think there is anything else that could supply the regulators.
You are checking with ground and remote only?
What scope setting are you using?
Ground and remote only yes.
And a BKPresision 2121. 30Mhz
Is there a way to disable the protection curcuit?
