Rockford Fosgate p1000-1BD.
I have the punch that has completely obliverated the power supply and 2 shorted output transistors. I have drive still on all the ps gate signal. My question is does this amp have 16ohm gates in q1004, Q1003, and Q100? Are they the same fet 75344G?. Q1000, Q1002, Q1005 have the normal 60.5ohm. the outputs are IRFP260N. I can't believe the drivers survived or ic. They complete burnt the mosfets off the pads.
both perry, I checked them i thought they were just out, until they all tested exactly 16 ohm. I thought they would all be 60ohm but the marking are slightlly visable now cleaned. Ill see if i can make out anything from the markings.
So I went with Irfp064n in the power supply and changed all the gate resistors to 47ohm. Powers up great, nice and cool. So my question, this amp runs the Irf260N in output section oem? Or did someone use them, Is that what I should use in it?
Ok I got them from mouser. Just making sure. The ps burnt up so bad and only two of the output failed. Since it has a all new ps, it will have all new fets in the output stage as well. I can see the drive signal when I probe the output drive board and a triangle wave on one pin. But not at output transistor locations.
