Return-to-zero shift register FIRDAC
Here is a picture of the board next to my earlier ES9038Q2M board. To make it apples to apples comparison I made the ES9039Q2M board more or less identical. However I discovered that simple dual mono scheme by paralleling dac chips as in ES9038Q2M does not work with ES9039Q2M so I have used only 1 channel from each chip. That is why I'll later replace the board with single chip version.
Are you saying that the 9039q2m does not support mono output to both L/R outputs? AFAICT this can still be acconmplished by setting registers 64/65 appropriately.
Regarding the above plots I noticed that the first one (ES9038Q2M) is somewhat fishy as the noise is too high. Here is a fresh measurement that shows similar noise as ES9039Q2M.
BTW all these measurements were made with direct DAC-to-ADC loopback without a notch which makes them less reliable. I will redo these with a notch later.
Thanks bohrok2610, I am happy with what you have presented and your plans going forward. All good references for future evaluations…
:cop:
@Endo2112 you are continually pushing your own agenda here As such you will find you are unable to post further in this thread, a thread which has nothing to do with your beloved ESS ES9039Q2M
Concerns have been voiced over your identity and motives from the outset. If this continues your membership will be terminated.
Thanks Mark, I am fine with this mod/upgrade using foil resistors which I intended to do anyway so don’t worry about reverting later on🙂
Jinkies! I just looked up the prices of foil 0805 resistors at Mouser. 😱
It's like soldering 20 dollar bills to the board! 😉 Serious ouch if one of those pings off and away during soldering!
I am wondering though if swapping out the Susumo 0.5% thin films for something with a better tolerance would represent a worthwhile improvement? Say Vishay/Dale 0.1%? They can be had for around £20 for the lot and maybe that is a cost effective way to gain some higher accuracy? Or will that extra accuracy not be noticed due to the nature of the circuit?
A single-bit FIRDAC is not nearly as sensitive to resistance tolerances as a multibit DAC, but tighter tolerances won't do any harm.
The main effect of a tighter resistance tolerance is that the notch in the response of the FIRDAC gets deeper, giving a better suppression of the idle tones around fs/2 (which could mix into the audio band when there is a spur on the reference or the clock around the same frequency) - if there are any such idle tones, which depends on the modulator algorithm. A secondary effect is less sensitivity to bit clock duty cycle fluctuations.
Obviously I don't expect any major improvements. If I did, I would have used 0.1 % tolerance resistors myself.
Some info on metal foil resistors attached.
An Excerpt from one document:
Also some info on current noise in metal film resistors.
Mark,
I know you're not the op-amps best friend, but when it comes to noise reduction with metal foils resistors, there is another way to achieve that, right in front of you.
When steering the Dac with a 0dB signal, you will get 66mVrms on the 8.2nF cap.
The 8 resistors, in parallel are producing ca. 339nV/rtHz over a 20Khz BW, which is slightly less as with a straight FR.
This calculates in a S/N of 20*log(339e-9/66e-3) = 105.8dB.
Now instead of tapping the signal at the 8.2nF cap but on the output of Marcel's first op-amp, output voltage will be 910mVrms at 0dB digital in.
With the OPA2210 noise at the output will be 1.37uV over a 20Khz BW.
S/N now becomes 20*log(1.37e-6/910e-3) = 116.4dB.
So, you would have gained 10.6 dB in S/N, which is much more than could be achieved with metal foils.
How's that possible almost like magic, well that's because the junction of 255R and 845R is a virtual input, so this low input impedance is in parallel to the eight Firdac resistors effectively lowering their voltage noise.
Hans
Reactions: mterbekke
Update: Pro hi end audio designer guy dropped by and listened to Marcel's dac with the RTZ circuit restored. He said, the space is back but the male voice doesn't sound right, its too weak in the midrange. He said, put the X5R caps back in. So I did. He then said it sounds way more open this way, much better. He said the voice is better but still isn't quite right so you have to work on that. Then he left.
