It seems to indicate that it’s pcm to dsd conversion is 48kHz. Well, at least the documented figures.AK4137 is available again. Recently got 10 from Digikey. They can convert PCM up to DSD256.
The output sample rate spec in the table at page 12 of the datasheet indeed gives the impression that everything is decimated to either 44.1 kHz or 48 kHz before conversion to DSD, but technically that wouldn't make any sense. Is it just an unclarity in the datasheet or a stupid internal interface definition by the AK4137 system designer resulting in a quite unnecessary decimation?
In either case, they are out of stock again at Digi-Key.
Still possible to get 1x Dac and Filter ?I have Valve DAC, DSC2 and Marcel's prototype RTZ but I have not done an objective comparison - they've been used in some different contexts and I consider all of them to be excellent and very listenable. I did post some listening observations between Valve and RTZ DACs earlier in this thread and that was with the exact same DSD data input arrangement and 'downstream' headphone based system. I suggest the best thing would be to build RTZ and form your own view of whether you prefer one to the other.
Thank you
Yes, I will PM you.Still possible to get 1x Dac and Filter ?
Thank you
This post from ppy seems to contradict that, it's probably just an unclarity in the datasheet. https://www.diyaudio.com/community/threads/simple-dsd-src-for-beaglebone.358147/post-7201934It seems to indicate that it’s pcm to dsd conversion is 48kHz. Well, at least the documented figures.
See post #88, https://www.diyaudio.com/community/threads/return-to-zero-shift-register-firdac.379406/post-6999623 for measured supply current values.I don't think i saw anywhere the power consumption of the dac. I have a silent switcher i could use, but i think its 5v (or 6.5v with external regulator) risk be pretty tight for the DAC + DSD modulator.
I've started to arrange onward delivery of the group buy PCBs and the first outbound packages will be collected from me on Friday. As the value is quite low and I have a few spare PCBs I am not including tracking to keep the cost down. I have updated the spreadsheet for packages ready to ship out and with the final settlement payment amount - would be good if people (highlighted in amber in the final payment column) could push settlement payments through to me via Paypal family and friends.
https://docs.google.com/spreadsheets/d/1uKnO0GdXeRVG1_gdMzKvs1F0184cyWlzM4Ul6nbt7Io/edit#gid=0
I'll get some more packages labelled up this evening and tomorrow.
Ray
Ray
The rest of the packages are ready to go and will be posted on Saturday morning. It would be good if you guys could reimburse me for the postage costs via Paypal 'Family and Friends' please, amounts are in column M of the spreadsheet.
I’ll sort the delivery payment today. 👍The rest of the packages are ready to go and will be posted on Saturday morning. It would be good if you guys could reimburse me for the postage costs via Paypal 'Family and Friends' please, amounts are in column M of the spreadsheet.
DoneI’ll sort the delivery payment today. 👍
Done.It would be good if you guys could reimburse me for the postage costs via Paypal 'Family and Friends' please, amounts are in column M of the spreadsheet.
- Digital Line Level
- Return-to-zero shift register FIRDAC
