Resurrecting a Crown DC300A
krmaudio said:
...PS does anyone want a **** load of dc300a amps, i cant give them away ...
Sorry, shipping cost too high but perhaps some other takers? Cheers!
AndrewT said:
how much would it cost to send one up to Scotland.
After reading this thread it sounds like it might make an interesting refurb/upgrade project.
That's the spirit! Wrap it well and ship it bulk on a train or something?
anatech said:
Hi krmaudio,Sure you can. I'm on the wrong side of the pond though. With shipping I could buy a new - whatever -. 🙁
At home here with my DC300A I actually ordered the output transistors last week. I should see them after Turkey Weekend! I'll have some more to post soon. Chris, I'm stilll looking for a local DC300A to ease my build. Keep your eye out.
Shawn.
"I can't remember the BGW 500 in particular. What was the issue with the 5 1/4" model? Overheating?"
Yes, the heatsinks had poor orientation for passive air-flow. The 7" model had the same chassis and heatsink as the 750. The 500 would put out the same power at 16 ohms as the 750, so it ended up on HF horns alot.
The 1000 had five pair of selected (for 170V ) 2N6259 per channel, 250W SOA at 100V (the MJ21194 only has 200W SOA at 100V)!
Hi djk,
Thank you.
That explains why I haven't seen any / many. I don't remember those specifically. In truth, I have to say that about most of the average amplifiers I worked on. Nothing to make them noteworthy.
Hi Shawn,
I told you I would. 😉 Many of those have passed through my hands as repair jobs. Then back to their owners. If you find one, you may find a bunch. I wouldn't mind playing with one. Still, a BGW 750C would excite me a lot more.
Cheers!
A new Driver PCB for Crown DC300A
I cooked up some pcb's last night to replaced the crown boards. The driver board is almost the same as the orriginal but I tweaked a set of pads for the new potentiometers to fit. I made some output boards but when I compare them to the orriginal Crown's, jeez the copper is so thick on them, I gotta keep them! So I'll strip them and remove the flux and gunk and I'll plate them with tin and they should look good as new.
Looking closer at the components on the orriginal Crown driver board, I just have to tip my hat to those folks back in the 70's because the components are top notch. Most caps are film foil or Mica. The mica's are 5% or 2% tolerance.
More to follow...
Shawn.
Poor pics
AndrewT said:
I hope your boards are better than your camera/photo taking technique!😉
Yeah thats pretty bad. 😉 Perhaps Santa will give me a nice SLR with macro options and a real tripod for Christmas this year? While I'm at it, I need a new color laser printer.
Can the ol fart do any thing for the shakes?:xeye:
I'll post better pics tonight when the 3 piece set is done.
Shawn.
anatech said:
Hi Shawn,
I used to use 2N3440 and 2N5415. I think they are still available.
MJE340 and MJE350 will work.
-Chris
Looks good and no pin-out changes :up: I can still use the round hat type heat sinks on them.
EchoWars said:
Zetex ZTX795A and ZTX694B.
More money perhaps? Zetex = High -end? Do they fab or package select die components. They are mentioned often around here but I have never seen.
anatech said:
Hi Glenn,
What case style are those in?
-Chris
The Zetex are TO92 and would not dissipate heat as well as the TO39.
Shawn.
FairChild NSD128
TomWaits said:
These are trouble at Q104 and Q204
Part Number = NSD128
Description = Si NPN Power HF Bipolar Junction Transistor
Manufacturer = National Semiconductor
V(BR)CEO (V) = 180
V(BR)CBO (V) = 180
I(C) Abs.(A) Collector Current = 250m
Absolute Max. Power Diss. (W) = 1.7
I(CBO) Max. (A) = 50n
h(FE) Min. Static Current Gain = 50
h(FE) Max. Current gain. = 500
@I(C) (A) (Test Condition) = 10m
@V(CE) (V) (Test Condition) = 5.0
f(T) Min. (Hz) Transition Freq = 100M
Status = Discontinued
Package = TO-202AA
Military = N
Looking for subs,
Shawn.
I think these did end up as NTE128's but the spec's have changed. I don't know who is right. This one is my biggest thorn. Any suggestions? Thanks.
Shawn.
