The words of physics and wine tasting is so much fun, applied to resistors.
Thanks.
The original post is a masterpiece.
Monsieur, I like wine degustations very much. I favor Bourgogne over Bordeaux.
No need to use a hammer. Your fingernails are enough. Try it on a phono interconnect, on a tantalum capacitor, or on a .... hm... on a resistor. It will work in a circuit of mV sensitivity, like a phono preamplifier.
Won't on mine.
To microphonics: The case with the switch weighs over 12kg so the resonance freq is below 20Hz. The switch was surrounded with 10mm aluminium all around.
Read about "expectation bias" to learn why resistors sound different. It's a well known phenomenon that has been widely studied.
What a nonsense! You mean all the different people from different races/religions/areas are hearing the same things because they are expecting it? LOL !!!
I just don't get it: People like you are not using ears but theories. You arguments are just theories but thousand of people are hearing it - but maybe you are deaf?
You are expecting that there is no sound difference because of a theory - FACT!
Where exactly in the circuit were the resistors placed? Across the input? In the feedback loop? Part of a filter network?
I use Dale CMF series resistors in the signal path. I have built the exact same circuit with CMF resistors, and then with "generic" resistors (carbon composition from a Radio Shack assortment) and the audible difference was immediately obvious.
In my "test" (no double blind just build and listen) the resistors were very different and the difference in the performance of the circuits was obvious in the measurements. I'm skeptical, but curious, about how you got audible differences out of resistors that are not so different.
Preamplifier like this one: Silicon Chip Online - 20W Class-A Amplifier Module; Pt.3
I used OPA1656 opamps and only 1 capacitor in series (after the pot). The 22k resistor in the input was tested.
From the cowanaudio website:
"The Pre-Pro is a Yamaha RX-V657. In bypass mode, essentially only the volume control is in the signal path and two channel audio is reproduced with utmost fidelity."
LOL!!! Gimme a break, no wonder that you can't hear any difference using crap like that. LOL!!!
I will ignore you in future.
So it's the input bias resistor. Any noise or anomaly introduced here in the circuit will be easy to identify.
It's also worth noting that this resistor is effectively shunted by the output impedance of the source. Theoretically, any "noise" produced by this resistor should be shunted out. In other words, you might get more dramatic results by switching out the 2-4.7K feedback resistors.
This circuit is essentially my buffered volume control circuit, which is a simple and excellent building block for line level circuits.
Yes, a lot of work went into that.The words of physics and wine tasting is so much fun, applied to resistors.
Thanks.
You are only using your ears to get an acoustic vibration converted into electrical impulses. A kind of biological A-D converter.
What you perceive is what your brain makes of that pulse stream. And that brain not only looks at the pulses coming in over the nerve, but also a lot of other data. Like how you feel, how you wish to appear to your friends, and your expectations, to mention just a few.
So the statement 'I use ears to hear those differences' shows a lack of understanding of how we perceive sound.
That is why controlled tests are so important to get to the real data, and not - without knowing - fooling yourself.
But you are not alone. Almost no audiophile is interested to know how the perception of sound works.
Jan
That's a good explanation of psychoacoustic effects.
What we "hear" is really a construct of our brains. Things like echolocation and "soundstage" happen in our brains, not in our ears. They are not perceived directly! They are cognitive constructs.
Every individual instrument you hear is sorted from the sound mass and perceived as a separate sound object in it's own space, it's a mystery how this happens, most psychoacoustics is conjecture.
Our hearing perception is very sensitive to sound source location. This is not an intrinsic feature of our ears. It evolved as a cognitive feature. We were at one time hunters (and hunted!) and our sensitivity to sound location was a big survival feature, so natural selection honed it until it became very acute.
Absolutely not. It is a very robust science.
Psychoacoustics is the scientific study of sound perception and audiology.
Psychoacoustics: The Psychology of Sound - The Los Angeles Recording School
Anyone involved in the design or setup of audio equipment should be well versed in these principles!
Jan
That is so funny and so true.
Look at how "audiophile" equipment is marketed. After reading a brochure I feel like I just got back from a first class world tour.
But what does that have to do with the equipment? Different strokes for different folks I guess. 🙄 I think you might know what it means to me. 😉 It's the same way they sell cars and everything else. They're selling an image, not a product.
Ah yes the insults of other people's systems. This is following the well trodden path down the plug hole.
There are a number of different theories on how the ear works, let alone how the brain processes the information it receives.
- Design & Build
- Parts
- Resistor Sound Quality Shootout
