Hi, I recently purchased Arcam Alpha One on ebay, from the start it struggled reading discs, once recognised it played OK, now it is refusing to read discs completely, it will start up most times if I spin the disc with my finger, not sure if this is a laser problem or just needs some adjustment or something, part of the problem was also at times the tray wouldn't engage fully to lock on the disc but this seemed to get better after some use. Could someone please fwd me the pdf. referred to aboe, I will try and change laser assembly and go from there.
email: terry.maddocks@hotmail.co.uk
Many thanks
Many thanks
Arcam Alpha 7se
Hi all,
I'm new to this great forum, and looking for advice.
I have an Arcam Alpha 7se that I bought new about 16 years ago.
This player has never been very good at playing CDrs' but recently it's been struggling to play any discs at all.
Sometimes it will take ages to read a normal cd but eventually will do, other times it will not read the disc at all.
And other times it will skip or only read some of the disc. Will a new laser assembly fix this?
Although I have some electronics knowledge I know nothing of cd players. If I replace the KSS240a laser assembly will the unit read CDrs' better? Or can I use a different laser to read CDrs' more successfully?
Any help with this would be greatly appreciated
Many Thanks🙂
Hi all,
Many Thanks🙂
Hello All, I'm new to the Forum and found it by searching on ways to repair my Arcam Alpha 7 CD Player.
I know this is a very old post but is there anyone out there that may have a copy of the PDF that is mentioned by Kora with instructions to replace a KSS-240a Laser Assy.
Thank you all in advance.
Regards Alex
Regards Alex
Hi All
I need this PDF for replace my SonyKSS 240a
There is someone could send me, please
Thanks in advance
Marco
Thanks in advance
Marco
Hi Marco,
I'd be happy to send you the pdf, but I need your e-mail address. Try sending it in a Private Message to me. Kora
check out the thread about
http://www.diyaudio.com/forums/digi...lable-but-ds-associated-mechanism-wanted.html
so as the attached files.
pdf for KSS-240A LASER REPLACEMENT ARCAM 9
HI, Cora', would you be so kind and send me a copy of the pdf for replacing the KSS-240a laser for arcam 9,Thank's my email is blakex29@yahoo.co.uk
Hey can someone send me this? My new laser is OK once its playing but it has great trouble changing tracks. I have a scope and would like to know how to adjust it.
Thanks!
liquidsmoke (--at--) earthling dot net
Thanks!
Thanks!
Have a look at this which covers full alignment of a KSS240,
http://www.diyaudio.com/forums/digital-source/226288-sony-cdp790-kss240-restoration-project.html
(what is this mythical document everyone keeps asking for ? The KSS240 is one of the most straightforward to replace)
Mooly; thanks for that. After reading around (I'm new to this) I think perhaps I will check the mechanism rather than the laser first as the symptoms I'm having seem to indicate an issue with the 'coarse' servo motor. When I seek within a track or seek to another track it has trouble finding the spot; it does eventually find it but it takes a long while.
You mention that these gears need to be left dry. What is the reason for this? I must admit I lubed them when I took it apart.
http://files.diyaudio.com/forums/gallery/data/1772/medium/xLoading_Gears_And_Belt.jpg
Pleased you have found it useful. The gears in question were the tray loading mech ones and if these are greased then over months/years the grease migrates and ends up everywhere. They also turn at a fair speed when the tray is moving which also flings the stuff around.
Your symptoms could still end up being a problem with the laser. I'm guessing you haven't a 'scope, which is really the way to diagnose something like this.
Hello, I'm a new poster on this forum. I've got an Arcam Alpha with a failing KSS-240a laser assembly. It's been a great CD player and I'd really like to get it running well again.
I'd really appreciate it Kora if you would e-mail a copy of your famous PDF. My e-mail is : peter.richards75@btinternet.com
Many thanks.
Many thanks.
I'm very intrigued what this mythical KSS240 pdf contains 🙂
The 240 is a dead easy unit to replace. This thread might give you some general hints on how to set one up correctly,
Edit... I see I posted a link to this last year.
Hi Mooly,
As I lack your experience and as Kora seems to have been similarly inexperienced before he replaced his laser assembly I think it wise for me to be cautious and see how he went about the task. If I do receive Kora's PDF I'd be happy to pass on to you for your expert opinion if he's agreeable.
Do you have any advice about the exact lubricants and cleaners you recommend in your restoration projects ?
Much appreciate your excellent description of the Sony restoration project - it's donkeys years since I last used a scope and regret not having one now but clear and concise articles like yours may inspire me to tool-up properly again !
- Digital Source
- Replacing Sony KSS-240a laser in Arcam alpha 7 CD
