Newbie DIY speaker builder here, wanting to convert a vintage 3-way speaker's woofer from a 4-Ohm 15" to 2 x 8-Ohm 10". The surface area of the dual 10" units are about the same as the single 15" and from what I have read, by hooking both 10" 8-Ohm drivers to the crossover in parallel will yield a 4-Ohm load.
Assuming I get the cabinet the right size, will this work?
The application is converting a Klipsch LaScala to use as a theater center channel so it can fit under the screen.
