Hello, new to forum. I've got an original set of ProAc Super Tablettes which use a discontinued SEAS 19mm tweeter crossed at 5kHz. One of them fried from an apparent power surge. Having looked around DIY forums, it would seem that replacing both with Vifa XT19's would be a more than appropriate substitution.
However, the XT19's are only available in 4-ohms, while the SEAS 19's are 8-ohms. Obviously a 4-ohm resistor is required to match the impedance for crossover values to remain the same, but the XT19's are only 2dB more efficient than the SEAS 19's, and putting a 4-ohm resistor in series would drop the output by 3dB. I'm concerned about how drastic it would be to fudge the resistor values to match sensitivities better while moving the HPF frequency slightly. I use these as studio monitors, otherwise I wouldn't hesitate to fudge them.
FYI I was really shocked to learn how high the x-over frequency is on these. I'm particularly sensitive to harshness in the 2-4k range, and these speakers are the least fatiguing I've ever heard despite being exceptionally detailed. I always credited the tweeter for that! Skan-Speak makes one hell of a good mid-high cone!
I'd appreciate reading about anyone else's experiences like this. Thanks!
Well in my experience (and pro audio convention) -6dB represents a halving of perceived volume, but half power output results in a -3dB change in actual output, i.e. halving perceived output requires reducing by 6dB either power or sensitivity (or a mixture thereof), a reduction of 3/4 of the actual output. Adding a resistor in series equal to the speaker impedance should result in half actual power output, or -3dB.
Is there something specific to hifi speakers I'm missing?
3 dB represents a halving of power, 6 dB represents a halving of voltage.
A resistor in series equal to the driver impedance will halve the voltage, so that's 6 dB and a quarter of the power. The reasoning being that halving the voltage also halves the current and P = IV.
Solen sells some Seas 19 mm silk domes, which should work as a drop-in replacement for your Proac:
http://www.solen.ca/pub/cms_nf_catalogue_fiche.php?id=500
Or you can simply replace the voice coils:
http://www.madisound.com/catalog/product_info.php?products_id=813
-jAy
-jAy
XT19 is a nice tweeter
But to just ad a resistor?
It may not be THAT simple
Anyway, doing what you suggest, you may not need as much as 4ohm resistor
8ohm drivers are usually around 5-6ohm
And the XT19 may be very close to 4ohm
Maybe you only need 2ohm res
But as said, it may not be that simple
May work fairly ok though
Or at least better than a total silent tweeter
just a basic, but to me an important question - is 4 Ohm tweeter going to sound louder than 8 Ohm of the same type (after appropriately adjusted 1st order crossover, no resistors) or after the cap it doesn't matter and their 'relative sensitivity' (compared to midrange) will be the same?
thanks in advance.
thanks in advance.
If all other parameters remain the same, the 4 Ohm version of a driver will sound roughly 3dB louder than the 8 Ohm version (at constant voltage from the amp). The high pass filter does nothing in this respect. It is hard to find two versions of the same driver though.
Ralf
Ralf
thank you Ralf. My point is this - i have cca 97db 10inch Siemens fullranger (8ohm) and i like corresponding paper tweeters. but there is obvious sensitivity mismatch, so i thought of looking for 4 ohm tweeter, to gain or 'cheat' sensitivity this way, adding those cca 3db..
- Replacing 8-ohm tweeter with 4-ohm
