We bought a new house and it came with a home theater that’s been pretty abused. I’ve gotten around to rewiring and replacing everything but the 10” old peerless driver which just blew. I can’t find the specs for this particular model.
I like it for what it has and want to replace with a similar or slightly better unit. Can’t be more than 5.5” deep. I need to reuse the box in the wall.
What do you guys recommend? 100-500 bux range.
There are some specs in this link, looks like a high qts/low VAS derivative of the 830452, probably for sealed applications? Sensitivity is excellent for a subwoofer, though it also seems a little unrealistic.
Peerless Cat # 830502 10" XLS Subwoofer Driver - Audio Asylum Trader
I didn't notice the coil was 4 ohms, which is where the increased sensitivity comes from along with slightly lower mms. Far as I know there's nothing out there that's a drop-in replacement.
You can get close with a SW26DBAC-4 woofer. I can't tell more without running some sims but that should get you in the ballpark. It ideally needs a little more volume (target is 40L sealed), but won't complain too much.
You will lose a ton of sensitivity though, so be warned. There's no subs made with 93dB sensitivity so you'll need to trim the mains accordingly.
Check this out: Scan-Speak 830772 10" Paper Cone Subwoofer 8 Ohm
It is advertised as a Scan-Speak driver but it is actually a Peerless 830772.
Interesting. It has 8 ohm. I also found this one SDF-250F75PR01 which has 6 ohm. So these alternatives mean that I’ll get slightly less output, but it can handle the wattage I probably have going to it.
I also found the XLS-P830452.
Which one would you go with?
Interesting. Scan Speak has 8 ohm. I also found this one SDF-250F75PR01 which has 6 ohm. So these alternatives mean that I’ll get slightly less output, but it can handle the wattage I probably have going to it.
If it were me I'd go for the 830452 XLS. I've heard these in a music/home theatre and they were very nice...especially at $145.98.
Peerless by Tymphany 830452 10" XLS Subwoofer
- Subwoofers
- Replacing 10” Peerless XLS 830502
