Hi everyone,
I'm in a process of repairing a vintage Saba CI310 integrated amplifier with burned outputs. It uses 2SC1827/2SA769 as an output pair (TO220 BJT's) which seem to be obsolete. Can someone recommend a modern (obtainable) replacement for them ?
Thanks,
Dudo
Thanks,
Dudo
Try here for some ideas; TIP41C pdf, TIP41C description, TIP41C datasheets, TIP41C view ::: ALLDATASHEET :::
That would be ideal for a multi-parallel output stage that gives a high level of ClassA current from a optimal bias triple EF.
Try 5pairs of 80W devices into 0r1 emitter resistors.
Bias to ~190mA each for a maximum ClassA output current of ~1.9A (=14W of ClassA into 8ohms) and a maximum output power of 160W into 8ohms from a 40-0-40Vac transformer.
Thank you guys
I put MJE15030/MJE15031 in as I could buy them in my neighborhood and it is singing again . With new transistors it was biased too high so I replaced one resistor in biasing circuit with multiturn trimmer which I had in my drawer and biased it to current level of the other channel.
