Replacement rectifier bridge for Threshold S500
usually it's either good or bad
if you have popping fuses - diode is shorted
if you have buzzing xformer , maybe even buzzing from speaker , diode is not conducting
so - all you need is diode test on DMM and maybe to disconnect one or two wires from bridge while measuring , to be sure
