Reflektor-D builds
For CM, is it okay to go higher than 22000uF to get a better capacitor (lower ESR, higher ripple rating, 105 celcius rated, etc.)?
I plan to use inrush current limiting. Would there be any problem with 33000 or 47000uF cap for CM?
I think that it may become unnecessarily rough on the diodes creating sharper rectification peaks (producing noise). Too much anyway for a steady current draw that will surely be below 1A and is already well covered with the smaller capacitor values. Unless when planning a central raw PSU for feeding several regulators all configured as DC input only. There it could be a big CLC even. So to have a rich quantity well filtered main distribution reservoir.
Salas I'm using the Reflextor-D to power Twisted Pear Buffalo III DAC, the requirements are 5,25-5,5VDC 440mA, my setup is 9V 30VA R-Core, R1 2R//1R5 = 0R86, the current is set to 698mA, the voltage is set with two green LEDs + 100R for RX, I used 12R as dummy load, the voltage across the dummy load is 5.290+
VDC.
Is the reg. working at the current edge?
Can I change RX 100R for 500R or 1K trimmer to set the Vout to 5,5 VDC?
It's possible that voltage drops
Conventional trimmer has many ppm. I would use the trimmer to find the correct value after warmed up (also watching not to start cold at some dangerous Vout) and then substitute a low ppm resistor.
The trimmer is for RX in the Vref not between the Ref-D and the buffalo. I don't know the BIII switches. It must have a max current draw spec. If your CCS is set above that it owes to stay at the voltage output you set. I think they used it in this thread before with BIII successfully? Set at a safe Vo with dummy, then stick the mA meter in between PSU & DAC to see if it draws much more than expected. The reading will go to the CCS limit if so.
First Ref-D I hear about not recovering from a fault. The current limiter usually saves it. Find what semiconductor burned or which Vref component is not touching well and change it. It will come alive again.
