"Reference" TDA1541A DAC with I2S-BUS architecture
Surface Finish for future PCB´s
  • ENIG - Electroless Nickle/Immersion Gold
    Votes: 93 48.7%
  • Immersion Silver
    Votes: 54 28.3%
  • Immersion Tin
    Votes: 24 12.6%
  • OSP - Organic Solderability Preservatives
    Votes: 20 10.5%
  • Total voters
    191
Thank you Oliver & Lucas for your help, I found the problem!😀
It was what we learned on our first day of electronics 101.
Make sure your GROUNDS are tight!!!:yell:
The input gnd to the converter was loose.
We're back in buisness, and sounding good, but still have a long way to go.
Best Regards,
Ned
Ahh ok 🙂 So have much fun!
I am looking forward to your ready build DAC 😉
Best regards,
Oliver
Lukas "Lampizator" Fikus has also staked his reputation on the fact that, when he set up an immediate A, B test to determine differences between output DC blocking, or "coupling" caps, he couldn't determine any single difference between any of them, including cheap electrolytic ones.
Go figure!
I must admit I was surprised by his findings. I found that using simple aligator clips to connect and reconnect caps realtively quickly made it fairly simple to check out the differences. I do suspect there is a lot of snake oil being sold at rediculous margin. I did on the other hand find differences in cap sound in this application even among the modestly priced units.
TDA1541A DAC V3.0 module progress report
A short intermediate result to the TDA1541A DAC V3.0 module.
The 1st testings with the module are finished.
Everything works perfect and i could tell you,
that also the SQ benefit from the new design and modifications.
Now the 2nd test with -ecdesigns- MK7 Onboard Grounded-Gate MOSFET Current Buffer I/V Stage will start.
To be continued...
:wave:
New TDA1541A DAC Module
The Red Baron
aka TDA1541A DAC V3.0
The evolution brings the following changes
- Direct shunt voltage inputs with shortest onboard traces
- I2S In-/Outputs with shortest onboard traces
- Upgrades DEM Synchronizer
- Onboard Grounded-Gate MOSFET Current Buffer I/V Stage
(-ecdesigns- MK7 version)
- Compacter design
Still on the module
- Separate GND-Trace for DEM-Synchroinizer
- Master/Slave connectors for parallel DAC module usage
and external I/V Buffer stages e.g.
Tube-I-zator & DDNF Stage
- Groundplane
- no SMD Design
If you want to use the onboard Grounded-Gate MOSFET Current Buffer I/V Stage,
you need additionally the DC-Reference Module
Description
Because the Grounded-Gate Buffer is connected between the DAC output and the passive I/V resistor,
normally the I/V resistor is connected between the DAC output and GND,
you must get rid off the approx. 4V DC on each I/V resistor.
Therefore we must get a new reference GND for each channel.
The circuit is connected to the ref.+5V at the output of the buffer and GND,
with a decoupling cap for each channel.
By trimming each voltage so it exactly matches DC voltage on the I/V resistor,
the DC voltage between I/V resistor and reference becomes zero.
In other words, the DC component is removed without using a coupling cap.
:wave:
Here you see the two configurations.
1st without the onboard I/V buffer stage and in parallel mod
The shortest connection between the two modules
for the I2S signal and the analog output.
2nd with -ecdesigns- MK7 onboard I/V buffer stage
Because of a small failure in my pcb design program it is necessary,
that you switch the source and drain of the MOSFET like in this picture
For a final subjective statement to the SQ of the onboard I/V stage, i would like to give it a bit more time to burn in.
All parts are complete new, including the TDA1541A. What i can say now is, that the sound is similar to the DDNF I/V stage.
:wave:
Any updates?
From my subjective side, the onboard I/V has a quite similar sound signature to the DDNF I/V stage.
Perhaps not that dynamical, but keep in mind you don't need any additional parts or modules. 😛
If space and more investment is not the problem, i would go with the DDNF or Tube-I-zator I/V stage.
In my rig the tubes stays with a different tube rectifier. 😉
