Reduce SMPS ripple noise for PreAmp?
I am using a Meanwell SMPS (reads 200mv ripple noise) to power a NE5532 PreAmp to a Class D Amplifier.
Would the ripple noise a SQ concern the PreAmp?
Is there anyway, I can reduce this SMPS ripple noise?
I use a pair of Mean Well SMPS bricks in my DIFF PRE 8x2 differential preamp. You can see the performance plots on my website.
I use a CLC filter on the output of the switching modules. At least with modern parts, that provides plenty of ripple attenuation to ensure good performance of the overall preamp.
Not to knock your choice of opamp, but newer parts, such as the OPA1612, LME49720, etc. have much higher PSRR than the humble NE5532 and are worth considering in your application.
The trick with CLC filters is to pick the components such that you get meaningful attenuation at the switching frequency of the SMPS without causing (too much) peaking in the filter response. Ideally, you would optimize the filter for the lowest supply impedance as well.
I tend to shy away from CRC filters as they raise the supply impedance by 'R'.
In my HP-1 headphone amp, I use a pair of Mean Well switchers with a CLC filter and a pair of LM317/LM337 linear regulators. That provides stellar performance as well. You can see the plots here: HP-1: Ultra-High End Headphone Amplifier
Tom
Thk Tomchar for sharing vast experience, any advice on the below situation:
Meanwell LRS-150 SMPS freq: 65KHz
Ripple =200mVpp
Output = 4.7A (i am using it on a integrated amp - so current drawn would be high)
appreciate any component & part value recommend...
I don't know that specific supply, so I can't make a specific recommendation. If the switching frequency is 65 kHz, you'll want decent attenuation at that frequency. You'll want the filter bandwidth to be at least as wide as the SMPS's regulation bandwidth and you'll want to avoid peaking in the filter response.
To make a specific recommendation, I would need to know the regulation bandwidth of the supply. If I was to take a guess, I'd say mid-kHz range, maybe. So design a filter with that cutoff frequency and minimal peaking that gives you the best attenuation as you can get at 65 kHz. You'll need to include the parasitics (DCR/ESR) of the chosen components in your design. You'll also need to make sure that the inductor won't saturate at the output current you intend to draw.
Tom
Appreciate your suggestion, am supplying fixed 32v from meanwell to this China-made amp; I would have difficulty supply this voltage on batt, in order to make comparison definite conclusive.
I would suggest that rigging up 32V from a battery supply is likely to be a lot easier than the learning curve you are going through from post #21 onwards.
Check if the amp module can operate with 36Vdc (or even 24V), and if so then use 3x 12V (or 5-6 x 6V) small vrla batteries (4-7Ah small monobloc batteries are very plentiful from any old small-medium domestic/commercial UPS). If 36V is too high, then series up about 10 1N400x and insert in series to drop the voltage a bit.
Just saying ...
Tomchr mentioned 70kHz... I dunno, but it is high frequency ripple. Here's a suggestion. U dont want a very large C near the output b/c u dont know how the feedback loop inside the SMPS is... There should be a datasheet stating max C. If you buffer the output with some resistance or better a choke, even a CM choke, u can probably go much bigger with the C since u probably isolate the large C from the feedback loop inside the SMPS that way.
Hi SemperFi,
Can you provide more details about this? I would like to use a single SMPS for multiple amps, each of which have their own onboard bulk capacitance, and presently there is way too much capacitance for the SMPS. If I can avoid having to add more SMPS units to power these amps, I would be quite happy.
I'm not interested in reducing ripple or noise, but to try to maximize the amount of output C I can use. Do those filters do that?
Also - I didn't mention this before, but it's an SMPS800RS 48-50 VDC SMPS for (at least) two TPA3255EVM modules, each with 9.4 mF bulk capacitance.
