Recommended 15" woofer for Open Baffle
This is plot which I generated using XIBaffle.xls
I used spreadsheet from Zoran (Thx🙂 and I put into datas for PRV and Faital. In summary I'm a bit confused because plot results is different than my 🙁
I comparison Beta vs PRV - PRV go lower but have less SPL, right?
I use a Eminence 3015LF in an OB at the moment with good result. It's one of the most efficient I've seen which means it keeps up with without the need to bi-amp, (in my case) & cone breakup is far enough away to filter passively if xover is low enough.. Bass does extend below audible on a narrow baffle, but not with as much power as a dedicated sub-bass.
