I wasn't disagreeing with you.I'm being quoted out of context here, this is pathetic. If you are going to comment on my posts try to read and understand exactly what I am saying rather than take it out of context so that you can appear to be correcting me.
You seem to have assumed that I used a lumped model in my paper, I did not as I stated earlier in this thread.
I wasn't trying to correct you.
I made no assumptions about your paper.
I was trying to clarify what I meant in my earlier post, and point out that what I was trying to say was in complete agreement with your earlier posts.
I also agree with everything you said about modeling in your last post.
Perhaps we can agree to agree?
It didn't sound like it, but good, let's agree then!
You also agree with Gedees who is wrong about the first resonance in a TL,
even if you approximated it with lumped parameters which I am not suggesting
the first resonance would in fact be the one modeled.
Referring to T&S type analysis which uses lumped parameters for traditional
systems it sounds as if you are suggesting there is a better way, please tell us
what it is if so.
OK, I'll try...
Agreed. So for a transmission line speaker, where the dimensions of the acoustical elements are large, the lumped model is only valid and accurate at very low frequencies (below the first resonance, in fact).
To be clear, this I disagree with since I was never speaking about a lumped TL model as I have stated several times.
can't self-quote as my earlier post was deleted, but I think Earl summed it up quite nicely here:
Quote:Originally Posted by gedlee
Lets please remember that these "circuit" type analogies are limited to LFs. Even at the first resonance of the TL these electrical circuits analogs are no longer valid.
And this I disagree with, again, never was talking about a lumped TL model and no matter how you try to interpret Geddes' statement it is plain wrong.
OK Ed, how about telling us more about the designs that produced those two very different SPL curves using the same driver. I have to admit I have not seen anything like that before and would be interested in more details.
Martin,
There is an analogy to the extended bass shelf vented type design.
Take a driver with a high Fs say 50 hz and tune in the 30s, adjust the box size to adjust the output at Fb. The response will shelf down and be a fairly good match for room gain as I pointed out probably 15 or more years ago on the Bass List:
The Subwoofer DIY Page - Extended Bass Shelf systems
I expected it would look strange
No, completely closed
Closed mass loaded pseudo TL🙄
I will see if I can spot a good woofer
Which direction to take it depends on whether it works and how
If at best, low bass with low Qts driver, and still being a closed system
There is a discussion of a closed TL that presents a mass load to a driver as far back as Beranek, probably further but it was a simple pipe not your construct. You will get no port augmentation obviously, so a high Xmax driver would probably be best. I've never tried to model this type of system.
Interesting post by Ken Kantor:
AudioKarma.org Home Audio Stereo Discussion Forums - View Single Post - Fact from Friction
"A- In no area of audio is the chattering of internet groups in any way, shape or form indicative of the true state of knowledge of actual industry experts. Almost all industry professionals avoid the internet like the plague, for exactly this reason. Internet debates are to the audio biz, what bar fights are to the Olympics."
He also states: "D- The relevance of, "transmission lines," is exactly what? What do they do well that is important to loudspeakers? Who still uses them?"
Bose still uses them and makes a lot of money at it!
The OP was shut down at AK also.
No, I think lumped parameter modeling is great for sealed boxes, reflex systems and the like.Referring to T&S type analysis which uses lumped parameters for traditional
what it is if so.
It's just with transmission line enclosures (and horns, for that matter), where the internal path length is long, that transmission line modeling is more appropriate (using T/S parameters for the driver, of course).
Sometimes the boundary can be a bit blurred. For example a very tall reflex box would be better modeled as a transmission line, but I gather those sorts of enclosures are referred to nowadays as "mass loaded transmission lines" anyway.
While tapered transmission lines and horns look quite different and have separate groups of enthusiasts, the same software modeling techniques ought to be applicable to both.
It would be interesting to compare results between e.g. Hornresp and Martin's TL software when faced with the same speaker design.
I put a vented design into Hornresp and it was way off as far as box size required to match the same design modeled in Unibox which I trust. My intent was to show that similar, if not better, responses to some of the unusual so called tapped horns or derivatives could be obtained with simple, smaller, vented systems. I tried hornresp in order to use the same simulator that the OP used and in order to see if the two simulators agreed:
AudioKarma.org Home Audio Stereo Discussion Forums - View Single Post - AK Design Collaborative - Insubnia
I don't know exactly what this "unhorn" is trying to claim to be, but I also did a comparison
to a traditional vented design in the same size box here. While the OP was showing big SPL
numbers the design was not significantly more sensitive than the traditional vented box. This
isn't exactly a traditional box since the port is about 30" long IIRC so there is some transmission
line behavior visible here:
http://www.hometheatershack.com/for...-trio8-unhorn-proof-concept-3.html#post208496
There are a lot of wild claims being made for these new tapped horns and I am interested in comparisons as a sanity check.
Generally if there is not a long slow taper ending in a large mouth it is not a low bass horn, lol!
I actually view many of these new designs as more like a TL derivative than a horn.
This one is based on the Radford/IMF kind of layout.
http://p10hifi.net/tlinespeakers/FAL/box-plans/classicTL-revisited-WD.pdf
dave
dave
Geez and they don't have a patent covering it?? So that's what that long wrapping channel behind the one driver in the WaveRadio is?? Who would have guessed.
Rob😀
Rob😀
It is a derivative and I do believe that they patented their improvements and probably tried to slip as much old art through as they could.
I put a vented design into Hornresp and it was way off as far as box size required to match the same design modeled in Unibox which I trust. My intent was to show that similar, if not better, responses to some of the unusual so called tapped horns or derivatives could be obtained with simple, smaller, vented systems. I tried hornresp in order to use the same simulator that the OP used and in order to see if the two simulators agreed. This
isn't exactly a traditional box since the port is about 30" long IIRC so there is significant transmission line behavior visible here:
numbers the design was not significantly more sensitive than the traditional vented box:
TRIO8 "Unhorn" Proof Of Concept - Page 3 - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com
Above post edited to fix a previous edit.
http://homepage.mac.com/tlinespeakers/FAL/box-plans/classicTL-revisited-WD.pdf
dave
Nice work, did you measure the minimum in the impedance curve to determine l/4?
Is that a 10" driver in the box designed for the B139 or B200?
I don't know if anyone has actually built this. The line is for the 10" SEAS used in the WD25 kit.
dave
dave
Oops, interesting!I put a vented design into Hornresp and it was way off as far as box size required to match the same design modeled in Unibox which I trust.
I'm not too enthusiastic about tapped horns either. When I see huge response peaks in the upper bass and lower mid, that immediately tells me that efficiency down in the "FR shelf" region is far from optimum.
The performance only looks impressive until you compare it to a large, properly designed (and preferably front-loaded) horn.
btw, I enjoyed your little calculation showing that 115dB(!!!) @ 400W = only 89dB @ 1W sensitivity. 😀
I don't see "Big, Load, Low - pick any two" changing anytime soon.
- Real Expert or Just Self Proclaimed
