RE xxx, wonky cone motion video.
No. Not unless the coils are on opposing edges of the cone. The voice coil former would be crumpled like a piece of junk paper.
That may be a passive radiator but it still doesn't explain the craziness, and is contraindicated somewhat by the presence of a nearby port.
What is that yellow thing in front of the speaker?
omfg
someone's playing a joke, that can't be a real functioning sub.
It goes all sorts of angles of axis. Unless this is some new two axis sub, not.
"stop motion video" comes to mind too. It may be a blown driver and they cut off the coil former and had their buddy push it in and out and speed up the video. Of course I really have no clue I'm just guessing.
proof?
Casey’s top-5 guesses as to what would cause such behavior in a cone:
Guess 5: A very, VERY angry rodent crawled in through the port.
Guess 4: You are playing something by The Artist Formerly Known as Prince.
Guess 3: A trainee at Midas (the muffler shop) saved you $37 by using your subwoofer cabinet as a muffler.
Guess 2: You live near the Oregon Vortex (http://www.oregonvortex.com).
… and finally …
Guess 1: You accidentally inserted your Windows XP installation disk into your head unit.
-Casey Walsh
Took the clip into video editor and found that the speaker is pretty spot on 10Hz all the way though the clip. too consistant to be a hand job. So the only thing I can geuss is, some one took off the magnet, voice coil and the spider, making only the surround holding the cone so it is sloppy, it's being used as a passive radiator and the boot is causing some kind of uneven force on the cone.
But what a waste of a nice speaker that would be.. I guess someone has many unpaid bills like me and needed a big fridge magnet to hold them 🙂
There is a part of the sub that cannot be seen from the front or back or sides that has PROBABLY been broken (due to abuse) that has made this woofer go madd...
Only people that know how they are built would know why its doing that... that particular customer has to send the woofer in......
Woofer porn (as it is called) is classified as abuse... Woofers like the Triple X are built to play music...not built to watch them move at full power just to video ... people tear up stuff that way....
