I would recommend the 6N2P-EZV as a substitute (not pin to pin compatible) as it is the USSR version of Telefunken's famous ECC808.
(check the datasheet and look at the noise figures for LF application!)
While I am at it, JB from Tubecad recently put up his version of the RCA circuit which is (to my mind) what it should be like.
If there's any interest we could turn it into a dedicated phono pre (MM mostly) with a volume control inserted after the last half of the 12AX7A/6N1P-EV supplemented by a dedicated WCF buffer and a very precise all tubed voltage regulator.
Cheers, 😉
Cheers, 😉
rca phono building
I'm also building this preamp and I'm very curious about how it will sound.
I am still confident because the rca electric scheme seems to me to be adopted by many manufacturers even if with small changes to the values of the components.
Hi from Chile Eli, i want to make this phonopreamp and i´m very interested in to do with your indication on this post but, i´m not sure how to do that, do you have the modified schematic for the final circuit?, please let me know and i hope your answer, thank you very much and greeting from ChileThe MOSFET buffer makes a world of difference. <snip>
