Hi I'm looking to build a headphone amp to use with the line out from a passive pre amp connected to a set of valve mono blocks so need RCA inputs and a traditional 1/4 headphone socket. I don't need a DAC or USB or anything too complicated just a good sounding headphone amp.
Headphone to be used Beyerdynamic DT 770 80ohm
I have built a few electronic kits so am reasonably skilled but obviously the simpler the better in this case as money is tight on this project so what would you guys suggest I build?
Thanks in advance for any suggestions/advice etc.
An O2 is well thought out,
http://www.diyaudio.com/forums/headphone-systems/193977-objective2-o2-headphone-amp-diy-project.html
Just for reference, if someone should pull this thread up in a search, the usual suspects for selling O2 headamps are:
Epihany Acoustics in the UK (their EHP-O2 is just an O2)
EHP-O2 Award Winning Portable Headphone Amplifier | Epiphany Acoustics
Head n' HiFi in Switzerland
Objective2 (O2) Headphone Amplifier
http://www.diyaudio.com/forums/head-n-hifi-walter/
JDS labs here in the US
https://www.jdslabs.com/products/35/objective2-headphone-amplifier/
Mayflower here in the US
https://www.mayflowerelectronics.co...iers/standard-objective2-headphone-amplifier/
...and Audio Poutine in Canada, but I'm not sure if he is still active
https://www.facebook.com/AudioPoutine/
http://www.diyaudio.com/forums/audio-poutine/
Most or all of these guys offer bare boards, kits, cases, ODACs, as well as assembled units. Many have a version with RCA jacks in the back.
With the exception of JDS I'm actually not sure how active *any* of these guys are now, best to check first. All of these folks were there from the first days back in 2011 selling O2s.
- Headphone Systems
- RCA input Headphone Amp, Any Exist?
